Rear Crank Oil Seal
Moderators:iRS, Art1012
stuarthardy
Rear Crank Oil Seal
Postby stuarthardy » Wed Sep 07, 2011 7:03 pm
The question is .......
Should I take the opportunity, whilst the engine is out, to replace the rope oil seal with a lip seal upgrade or take the chance that the current one on my totally rebuilt engine won't leak.
If the consensus is to replace then how far do I have to strip the engine to get the crank out?
Stuart
1962 E-Type FHC
1969 420 Daimler Sovereign
1994 X300 XJR
piman
Re: Rear Crank Oil Seal
Postby piman » Wed Sep 07, 2011 7:57 pm
Hello Stuart,
have you run your rebuilt engine, and if so, did it leak?
I don't think I would bother fitting a lip seal, unless there is a bad leak.
What's involved in fitting the kit, does it entail drilling the block for the housing?
