hand brake
steveandtina
Re: hand brake
Is yours a manual? A bad handbrake is usually down to lack of use on the automatics - but a bad handbrake will fail the MOT so it can't be that bad? Maybe you need it adjusted or new shoes fitted? My car failed its MOT because of it so i am all too aware of it now
New shoes sorted that problem out
Re: hand brake
make sure the central swivel on the cable is free and working both sides...
Re: hand brake
if it is a 308 it WILL be an auto, I would check, clean and adjust and if needed replace the handbrake shoes, this cures most problems
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
