Flat Battery
Moderators:robv12, DavidEm
b_partridge
Flat Battery
Postby b_partridge » Sat Apr 10, 2010 12:29 pm
I have an 02 x308, 3.2 SE. Ive managed to leave an interior light on and the battery is totally flat. How do I charge the battery, its in the boot and I cant get in there. Is there a terminal under the bonnet?... Any hlep greatly appreciated.... Cheers
b_partridge
Oopss
Postby b_partridge » Sat Apr 10, 2010 12:39 pm
Ermm... Bit previous with my request for help there. The lock on the boot must be stiff, turn the key with more force this time... and Pop... it just opened.... Can you tell im new at this?...
joejag308
IT JUST POPPED OPEN
Postby joejag308 » Sat Apr 10, 2010 8:36 pm
Ive heard that before somewhere............another time maybe.....but, while you are on the subject.......we handsome lot in here keep telling you all to try your boot locks while you still have some life in the battery...........squirt some WD40 into the boot lock and when its free stick your key into the copper grease tin and put it in the lock so the grease can be inside...........then if you let the battery go flat by not having a Cetec...charger..........it will open via the lock................SIMPLES
Postby J44EAG » Sat Apr 10, 2010 10:25 pm
Grease and WD do not go together I`m afraid.
It turns to a sticky sludge when the WD evaporates.
A drop of sewing machine oil only is rather better.
Sorry to contradict. Mixing lubricants causes more trouble than it solves in the long term.
robv12
Postby robv12 » Sun Apr 18, 2010 2:03 pm
of course don't forget if the battery is flat and the lock is seized, which is common on 308 and indeed 300's pop the bonnet and locate the positive terminal, add a jump pack and you can energise the car from here, pop the boot from the remote release in the car , Roberts your fathers brother!
joejag308
BOOT LOCK LUBRICATION
Postby joejag308 » Tue Apr 20, 2010 12:08 pm
THE REASON WE DO TRY TO COME UP WITH SOME PREVENTATIVE METHODS IN THE 308 .....ONE OF WHICH IS THE LUBRICATION OF THE BOOT LOCK MECHANISM....A CONSTANT OCCURENCE....THEN IF THAT IS WORKING YOU CAN GET TO THE BATTERY...........Joe
joejag308
Re: Flat Battery
Postby joejag308 » Fri Jul 08, 2011 10:48 pm
S5015 BOSCH SILVER PLUS Car Battery
12V 110Ah CCA 950 3YRS Warranty
£96... :shock: Thats a discount price too
....Batterys sure have gone up but if you want or need the top ones dont go the cheap route.......i just had a new battery fit (above) 10/ 07 / 2011 the best one evidently for my 308 Super v 8.....but with all the gismos now on these cars what else can you do......dont forget to keep the boot lock lubricated... :cry: :wink:
bmc123
Re: Flat Battery
Postby bmc123 » Sat Jul 09, 2011 2:15 am
I have one of those Bosch ones - Highly recommended, and I also cannot stress enough the importance of putting a good battery into these cars.
savXJR
Re: Flat Battery
Postby savXJR » Wed Apr 02, 2014 9:01 pm
I haven't used my XJR for a while and the battery has gone flat and I cannot get into the boot. Where is the positive terminal under the bonnet?
Re: Flat Battery
Postby ptjs1 » Thu Apr 03, 2014 8:59 am
It's on the bulkhead close to the inner wing. It's probably covered by it's rubber boot still. Remember to refit that after use. Also be careful where you use as an earth point. Some areas such as the top of the suspension strut (which is quite close) may not work properly because they are insulated.
