Noise apparantly from the direction of the instrument panel
ricky158
Postby ricky158 » Sat Mar 13, 2010 7:08 pm
When switching the ignition on there is a noise from behind the dash that I can only liken to mice running. This is before the engine is started. On switching off, the noise is repeated, followed by a loudish click and the needles on the dash jerk. Any suggestions as to the problem?
Telsmoneypit
Postby Telsmoneypit » Fri Mar 26, 2010 12:44 am
If this noise was evident only on switching on, I would have suggested ABS pump charging BUT you say it also occurs on switching off....
Dunno.
Clean all the electrical connections and hope it goes away.
It works for me! :D
ricky158
Noise from behind dash,[mice?]
Postby ricky158 » Fri Mar 26, 2010 10:21 am
Thanks for the advice Tel, I think it has gone away! :D
cotoole
Postby cotoole » Wed Mar 31, 2010 10:39 am
I had the identical noise and jerking of dials about 2 monts ago.
It was a time when the rain was excessive and also the cold weather. However, as the weather has cleared, so has the noise. I rekon it was water leaking in somewhere in the dash.
Chris Galway Ireland
ricky158
Noise from behind dash.
Postby ricky158 » Wed Mar 31, 2010 5:26 pm
Thanks for the comments Chris, you could well be right, all now seems to be normal. Strange! Thanks again, Richard.
