front wheel bearing. special tool.
Moderators:robv12, DavidEm
royunsworth
Postby royunsworth » Mon May 24, 2010 1:03 pm
where can i aquire the special tool for removing / replacing the ABS rotor nut, i'm stuck & the main agents are unhelpfull. roy
Postby Brakebuster » Mon May 24, 2010 5:39 pm
hi
you can buy or hire from the JEC / JDHT
just follow the links at the top of the page
but they aint cheap ,
royunsworth
Postby royunsworth » Mon Jul 19, 2010 8:14 pm
thank's for the info. i've managed to make up a tool in the lathe & using a template to drill the series of holes. a old 3/4 drive socket was welded to it to transmit the torque. can't belive how tight the abs rotor nut was though . anyway job done, thank's again. Roy
Postby Brakebuster » Mon Jul 19, 2010 10:18 pm
cool
lust like i made a spring compressor from some threaded rod and a part from my petrol brush cutter, lol
dont want to sell your part do you , i fancy changing out my front bearings
