Wheel Nut Torque
Moderators:robv12, DavidEm
joejag308
Wheel Nut Torque
Postby joejag308 » Mon Apr 21, 2008 2:07 pm
I have always set my wheelnut torque to 60 nm and im told it could be wrong........anyone know the real setting for the wheelnut torque?
Joe
daveji
Postby daveji » Mon Apr 21, 2008 4:58 pm
Yep
88-102nm (nominal 95nm) for my Celtic Alloys
Should be the same for any other Alloy I would think.
joejag308
Wheel Torque
Postby joejag308 » Fri Apr 25, 2008 5:34 am
Spot on there Dave, but i have just bought a new torque wrench and the Nm measurement is not on it .......any other measurements LBS ect
daveji
Postby daveji » Fri Apr 25, 2008 7:40 am
1n/m = 0.738 ft/lb
so 95n/m = 70.11 ft/lb
Will that do ?
joejag308
Will that do ?
Postby joejag308 » Fri Apr 25, 2008 8:01 am
Looks like it will have to do........as im thick and dont know any different
i set my torque at 85lbs off the cuff anyway.......... :lol:
Postby Brakebuster » Fri Apr 25, 2008 4:50 pm
i do mine up 'FT' i dont need to translate do i ?
BB :wink:
joejag308
"FT"
Postby joejag308 » Fri Apr 25, 2008 5:54 pm
Mind you dont crack the alloys........its happened :shock:
Postby Brakebuster » Fri Apr 25, 2008 6:23 pm
'FT' doesnt mean ' Ham-fisted ' :P
but i do agree, dont over tighten alloy wheels, and also ensure you have the correct wheel nuts for your particular wheels, as the ones for steel wheels will chew up alloys and make them unusable due to the damage caused
if in doubt, do it by the book
another safety feature i follow is to put the caps ( for the nuts or the actual wheel ) in the boot while doing the work, the action of having to get the cover after she is dropped to the ground reminds me to ' check ' the tightness of everything with the bar before fitting the covers ,
well, it works for me anyway , lol
BB :)
joejag308
A Laugh
Postby joejag308 » Sat Apr 26, 2008 6:37 am
If you had seen me with the wheels, putting them back on, you would have had a right old giggle.
Guess who didnt realise they are offset on the studs, and got rather irate to say the least.......even for a younger man they are quite heavy wheels........... :oops: Joe
