Never understood what sense fitting the stock part was when the ali one has been around for almost 3yrs (albeit not quite 2 in the UK).
Also £58+Vat at British parts:
http://www.britishparts.co.uk/.sc/ms/dd ... -ALUMINIUM
Am keen to do this when the weather improves so if someone has a step-by-step guide (or thinks of doing one) I'd be grateful. Have to do a rad change (probably the only original item left on my 6 Oct 96 registered car) and coolant flush in summer as from previous experiences it's always preferrable to do when warm.
Mark
LPG XK8, steel linered, 2005 spings, full polybush set, McLeod X-pipe 'Cat's Roar' 11-speaker inifinity kappa system, smartnav, DAB tuner, Parrot handsfree, aerial cut off switch, 3 x aux power sockets, OEM Xenons, cruise lights, 2003 rear lights, LED rear lights, LED blue interior lighting. Running on 5w30 Royal Purple fully synth, bespoke Apexi intake with iridium plugs.
