Could somebody please have a look in their owners book and let me know the capacity of the cooling system and the recommended a/f percentage.
With thanks -- Tony Walker.
Cooling system capacity and antifreeze percentage.
Hi Tony,
coolant details,
4.0 ltr XK8 including reservoir & climate control ----- 9.5 ltr
XKR ---------------------------------------------------------11.5 ltr
50% Jaguar antifreeze conforming to Spec:- WSS M97B44-D
50% Water
Gives protection down to -40 c can be left for 5 years,
all the best ,
Bob
coolant details,
50% Water
all the best ,
Bob
Jaguar changed antifreeze types during the life of the XK8. Early cars used conventional antifreeze and later cars used the long life type. Underbonnet labels were fixed to avoid the risk of mixing the two because together they create a gel which makes a nasty mess in cooling tubes and can result in (very expensive!) overheating. Stick with whatever type Jaguar used and this problem will be avoided. Mike.
Thanks for that Mike. My car is 1997 but the only underbonnet label is on the header filler cap and carries the number MJA444OBA. I had intended flushing the system and refilling with new a/f but without a ramp I found it difficult to drain the system so ended up replacing only 1.5 litres of 'pink'.
In the light of your info. I'm a bit uneasy about using the car, any suggestions gratefully rec'd. -- Tony.
PS. - What would pensioner XK owners do without this forum ?
