Strange things happening with security system
Posted: Fri Jan 05, 2018 10:19 am
I apologise in advance for a long post, I'm having some strangeness happen with what I think is the security module.
Drove to work all ok on Wednesday, parked up, and locked with the fob. Five hours later went to pop out on my lunch break and the key fob didn't work. I thought it might be the buttons getting lazy, so used the key, the central locking fired and opened all the doors, rushed to put the key in the ignition and realised that no chimes to warn me I have 7 seconds to comply. Dashboard comes on, and no warnings, but she refuses to turn over.
A couple of things I had noticed Tuesday night though, doors seem to operate the central locking randomly while driving, and the tick tock sound when the indicators work goes at double time which I thought meant one of the bulbs has gone, but all are ok when checking. Driving in to work Wednesday morning and all back to normal haven't had any of those problems since.
I called my breakdown service out as I thought it was the battery and no-one at work had jump leads. The breakdown guy had a look and he tested the battery and said it was ok but just needed a charge. So he connected his booster, but it still wouldn't start. We then realised the immobiliser wasn't deactivating. He said then an ECU reset should sort that, which got the car started, but fob still isn't working.
There was a bit of water in the spare wheel well so I've dried out the interior of the boot (trunk), checked the slcm for shorts etc and it's all ok no burnt out bits. I had to lock it Thursday night with the key as the fob wasn't working and assumed I had to reprogram as had disconnected the module. Thought to myself, I'll do that in the morning. Well yesterday morning without me having to do anything the fob worked! Drove to work and parked up. Fob not working. Locked car up and left it until my lunch break. Went out, fob working again. Drove it to local Tesco, turned car off, fob not working again, went back to the car fob still not working. Got back to work, locked the car with the fob! Came out after work fob not working. Unlocked it with the key, engine wouldn't start, immobiliser still active, opened the boot with the key as the growler button didn't work (although this morning it was working), to disconnect battery and reset ECU and the alarm went off. I put key in ignition to turn off alarm and the car started!
This morning, had to unlock with the key, got the chimes to get the key in the ignition and she started all ok, drove to work, went to open the boot with the button on the dash, which is working, and the display is showing Valet Mode and I get the chime. Had to unlock it with the key (no alarm this time).
It's driving me absolutely batty! Does anyone think it would be worth looking at replacing the SLCM? Or could suggest what else I should check?
