Climate control temperature display
director240
I've just noticed that part of the air con temperature display has gone slightly dark. I assume that a bulb has blown, does anyone know how to replace it?
Re: Climate control temperature display
I have this problem on my 2001 Daimler SV8. Left side of the temperature display is dark but the number is just visible.
Anyone know how to replace the bulb?
TIA!
TIA!
Hi David,
That screen if I remember correctly has two bulbs,one each side.
Part number is JLM11965
You will have to remove ski slope and remove centre control panel to access the bulbs.
Hope that helps.
Take care.
Hope that helps.
Take care.
And removing those is fairly straightforward, fortunately! Plenty of videos on YouTube showing how to do it.
XF Sportbrake 2020 / XK8 1998
