door not opening from the inside
Moderators:robv12, DavidEm
TROY
Postby TROY » Fri Aug 05, 2011 5:12 pm
hi all
having owned my xj8 for about 2 weeks i am absoloutely over the moon with the car.
i find any excuse to take it out and drive it.however once you start familiarising yourself, you do get to notice a fault or two. my n/s/r door doesnot open from the inside. the door works fine from the outside handle. any ideas guys would be much appreciated
cheers troy.
Re: door not opening from the inside
Postby ptjs1 » Sat Aug 06, 2011 10:19 am
Troy,
Sounds like the Child-lock is set on.
TROY
Postby TROY » Sat Aug 06, 2011 12:01 pm
cheers for that paul,
i have checked the child locks,that doesnt seem to be the problem
troy
Postby ptjs1 » Sat Aug 06, 2011 4:50 pm
Troy,
If the child lock on that side is definitely off. then it feels that it could well be the adjustment of the pushrod from the internal handle to the lock catch.
Check the child lock catch one more time on that door and then, if no joy, it's time to get the door card off and check the adjustment.
Postby Brakebuster » Sun Aug 07, 2011 11:39 am
almost....
it should be a cable ( like a bike brake cable ) , they are known to come out ,or even snap due to lack of use.
fairly easy to replace
Postby ptjs1 » Sun Aug 07, 2011 6:28 pm
Tks for the correction, BB,
I'm clearly spending too much time in the XJS that has rod actuation of the locks!
