Sheepskin Rug Cleaning
Posted: Sat Apr 11, 2009 9:57 am
by joejag308
It took longer than i though it would to find official cleaning methods for Sheepskin / Lambswool rugs for 308 vehicles........
Single and double fleeces fit comfortably in standard British washing machines, while treble fleeces may fit into larger machines. Use the coolest ‘woollens’ settings – an absolute maximum temperature of 40, preferably 30 degrees – and add just a teaspoon of mild, non-biological detergent. Lightly spin the rug and then allow to dry naturally, away from direct heat.
If hand washing, use warm water (not hot), and again use just a teaspoon of mild, non-biological detergent. Gently squeeze out excess water, carefully pull the rug back into shape, then hang to dry away from direct heat. Flexing the sheepskin as it dries will help to maintain its suppleness.
Carefully brush the wool with a wire dog brush once when damp and again when dry, to maintain the silky soft texture of the rug.
NEVER tumble dry.
NEVER dry on a radiator.
NEVER store in a plastic bag.
NEVER use biological washing detergent.
NEVER use bleach.
NEVER wash in hot water.
This is a bit more cleaning information for a not so easy task.......if you do it wrong its an expensive item to replace......Joe
Re: Sheepskin Rug Cleaning
Posted: Thu Apr 26, 2018 11:02 am
by reyan19
Hey,
Please give some tips about the clean and wash a characteristic sheepskin floor covering and How to wash a sheepskin mat????
Posted: Sat Jun 23, 2018 1:24 pm
by ancrysedflex1978
Hey,
Can anyone suggest me the best carpet cleaning tips? Because my carpet is too dirty and I want to clean it, so please suggest me some tips for the carpet cleaning.
Thank you :)
Posted: Sun Jun 24, 2018 5:02 pm
by Andy P
If you look after your sheepskin rug it will give you many years of enjoyment. But accidents do happen and here are some helpful hints and tips for you to keep your sheepskin looking like the day you purchased it.
Obviously if the sheepskin is used as over rugs in the car they will start getting shabby a lot sooner than if it is used as a decorative item.
Your sheepskin is a natural product that will not appreciate strong sunlight or damp conditions. Strong sunlight will bleach and dry out the skin. While damp floors will attract black mould and make the fibres curl up. If your sheepskin does get wet then dry outside away from the sun.
Giving your sheepskin a good shake outside and regular brushing will help maintain the wool fibres. Any good pet shop will have a wide tooth metal brush, normally associated with dogs, but is equally good for brushing out sheepskin rugs.
There should not be any need to wash your sheepskin rug, I usually find the natural lanolin and wool fibres that are present tend to have a barrier that protects them from dirt.
If you need to wash your sheepskin I would suggest any small spillage should be immediately spot cleaned with a clean damp cloth and light wool detergent. Sometimes if it is dirt you may possibly be better letting the offending item dry out completely and simply brushing the dirt out.
I do not recommend fully washing a sheepskin rug, but if you feel the need and have some experience then the manufactures or suppliers of the rug should be contacted for advice. I have in the past washed on a wool wash cycle on a very low temperature in a washing machine or by hand preferably no hotter than 30 degrees, use a teaspoon of non-biological washing powder, or a specialist wool shampoo. If you have a large rug you will need to wash in a bath tub by hand using luke warm water. I also add a teaspoon of glycerine to the water as this helps to keep the back of the Sheepskin rug supple.
Do not use biological washing powders, soap based powders, soap flakes or conditioners or any detergent containing enzymes.
DO NOT tumble dry, DO NOT dry on a radiator, DO NOT use bleach, DO NOT wash in hot water.
Always dry naturally, away from any direct heat, including direct sunlight, preferably in a shaded room with no heating or outside on a cloudy day.
Unfortunately the drying process can take some time, so it is always best to wash your rug in the summer months, but not in direct sunlight. It is advisable to brush the wool of the rug whilst wet with a wide toothed wire brush or pet brush. This will allow the air to circulate through the fibres of the wool and help to stretch out the fibres to stop them from going too curly. Once your Sheepskin Rug has completely dried out give it a good shake and another good brush through, then you are ready to place the rug back in the car.
Like everything I do with my car,taking care,being thorough and patient is the order of the day and you should get the best results.
Hope this helps.
Enjoy the luxury that is the X308 :D
Take Care.
Andy 8)
Posted: Thu Jul 12, 2018 9:06 am
by denish21
How to remove the stain of oil from the rug?? I have tried to clean it on my own, it has just faded but not gone completely.
