Grotty, slow driver's seatbelt
Moderators:robv12, DavidEm
Davidqhog
Postby Davidqhog » Fri Dec 29, 2023 6:51 pm
The belt on my side of the car is looking dirty and rather unkempt and it only reels back in with manual help.
Should I get a new belt or is it possible to refurbish it myself?
TIA
xjray
Re: Grotty, slow driver's seatbelt
Postby xjray » Sat Dec 30, 2023 12:34 am
Try pulling it all the way out, holding it with a clip of some sort, and give it a good scrub on both side with soapy water and a fairly stiff brush. Leave it pulled out until it’s dry and you’ll probably find it will retract properly.
You could also try something like this: https://www.meguiars.co.uk/product/carp ... ner-473ml/
Cheaper than replacing it :wink:
Ray
1986 Series 3 XJ6 Sovereign
andypryce
Postby andypryce » Sat Dec 30, 2023 11:13 am
Hand washing powder is good for this, as stated rub it in and then use old dry towel to repeatedly dab it to get as much dirt off as possible.
XF Sportbrake 2020 / XK8 1998
Davidqhog
Postby Davidqhog » Sun Dec 31, 2023 6:06 pm
Thanks Andy & Ray.
If it ever stops raining, I'll give that a try!
Postby davidr » Tue Jan 02, 2024 5:08 pm
Hi - I had a similar issue on my XKR. Giving the belt a good wash (I used washing up liquid) made it both look much better and restored its flexibility. I also gave the belt a squirt of silicone spray and it now looks good and retracts easily.
Users browsing this forum: No registered users and 14 guests
