Drooping headlining - temporary fix?
Posted: Sat Jun 08, 2019 9:37 pm
Seems I now have that well known problem with the sagging headlining... Incredibly the original headlining in my '98 XJR looked perfect up until just a few weeks ago, but then following a short spell of warm weather I noticed a slight droop just starting to appear over the back seat. Now that droop has got much worse, and has spread to other areas - most annoyingly, directly above the driver's head!
I know the only permanent fix is a new headlining, and fortunately there is a bodyshop less than twenty miles from here who have experience of carrying out this work. It's something which I plan to arrange for later this year. But in the meantime can anybody suggest a temporary fix?
I've seen sagging headlinings pinned up using stationery staples in the past, but apart from looking unsightly I understand these have a tendency to keep falling out (I'm assuming the foam board behind the headlining is not particularly thick to press pins into?) Can anybody recommend a type of pin / fixing which could be used for this job? Or, indeed, any other means of effecting a temporary repair? I'm hoping I should be able to get the headlining replaced before Christmas.
Thanks in anticipation.
John.
John.
