boot locked shut
Moderators:robv12, DavidEm
robv12
boot locked shut
Postby robv12 » Tue Dec 18, 2012 10:17 am
I have been conatcted by a member whose XJ8 boot is locked shut, key will not work and both release buttons have stopped working, here is is email
I hope you can help here. I have a 1998 XJ8 on which the external electrically operated boot lock failed some years ago, as did the mechanical one. I wasn't too bothered as the key fob and dashboard buttons still worked fine. Today, however, these too have failed and my boot is locked with a considerable number of tools inside!
Before I cut a hole in the metal, can you offer any alternative options for unlocking the system?
anyone got any ideas??
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
Re: boot locked shut
Postby Brakebuster » Tue Dec 18, 2012 10:39 am
nup
seems like all the bridges have been burned
i would say , get the drill out, but its probably in the boot......
other than using liberal amounts of WD40 in the lock , and keep trying the key with a small amount of ' bouncing ' pressure on the boot lid to see if it lets go ,
then wash everything in wd40 , clean off and grease up as required
good luck to him
BB :|
robv12
Postby robv12 » Tue Dec 18, 2012 11:05 am
as i thought all my avenues exhausted as well!!
R
Postby ptjs1 » Tue Dec 18, 2012 10:20 pm
Boost battery connected via the positive terminal point under the bonnet and keep trying the dashboard button. It may eventually succeed. My car is a bit prone to the same problem.
You really don't want to drill the boot unless you have to.
Postby Brakebuster » Tue Dec 18, 2012 11:12 pm
if none of the buttons work , and there are three plus the key , then i would imaging the solenoid on the lock is fubar ?
lets hope not
steve_m
Postby steve_m » Thu Dec 20, 2012 11:46 am
I seem to remember from another forum (although I'm sure which model) that you can remove the number plate and drill below the lock to access the lever.
It might be wroth having a look at another one to see where all the bits are laid out in relation to each other before attacking with a drill/hole cutter.
1995 XJR6 Flamenco red
2004 X Type 2.5 Estate
Car-Nut
Postby Car-Nut » Sun Dec 23, 2012 3:29 pm
Rob,
This happened to me on my x330
I wrote in and the article was published I think about April 2012 JEC magazine
Clive
(Car- Nut)
MK7, 8 & 9 Forum Co-ordinator
MK10 420G Forum Co-ordinator
:arrow: 1970 - 420G - WiP
:arrow: 1962 - E-Type FHC
:arrow: 1997 - X330 4.0
