Drip moulding finisher
Moderators:robv12, DavidEm
missjaguara
Postby missjaguara » Thu Sep 06, 2018 12:44 am
Hi all,
My name is Gabriella, I'm a new member of the forum, I showed up in the appropriate area.
I'll have to completely repaint my X308 and to do that I want to disassemble everything as much as possible. I'm in possession of the workshop manual of this car, but I could not find the procedure to remove the chrome roof mouldings (or drip moulding finishers parts HNA5701BE and HNA5700BE).
Does anyone know how they are fixed? I think they are glued with the double-sided adhesive like many other parts, but I would like a confirmation if it is possible.
Thanks at all.
Gabriella
Andy P
Re: Drip moulding finisher
Postby Andy P » Thu Sep 06, 2018 2:09 pm
Hi Gabriella,
I know the XJ40 ones have screws and the X350 has clips but I'm not sure about the X300/X308,there's no mention of any fixings on Jaguar Classic Parts or in the workshop manual.
No. Description
1 + B/C-post finisher
2 + Drip moulding finisher
Link provided
https://www.jaguarclassicparts.com/uk/j ... d-finisher
Perhaps it is just stuck on in which case it will require careful removal.
I did find this in the workshop manual though,It say's it for exterior trim removal.
Exterior Trim and Ornamentation - A-Pillar Moulding RH
Removal and Installation
Removal
Installation
1. Remove rear grab handle. Refer to 76.58.30.
2. Remove draught welt from adjacent section of door aperture
flange.
3. Using a trim removal tool, carefully ease the six trim pad fir
tree fasteners from cantrail and upper'A' post locations.
4. If premium ICE is fitted, carefully withdraw trim pad for access
and disconnect tweeter connectors.
5. Remove trim pad from vehicle and remove tweeter. Refer to
415-03.
6. Remove and discard fir tree fasteners.
1. Fit new fir tree fasteners to the trim pad.
2. Fit tweeter to trim pad. Refer to Section 415.
3. Position trim pad for access and connect tweeter to harness.
4. Commencing at top of 'A' post and working rearwards, fully
seat three fir tree fasteners.
5. Fully seat remaining three fir tree fasteners in upper'A' post.
6. Fit grab handle. Refer to 76.58.30.
7. Fit draught welt to adjacent section of door aperture flange.
It is on page 2100
Sorry I can't be more helpful.
Good luck and hope that helps a bit.
Take Care.
Andy :D
missjaguara
Postby missjaguara » Thu Sep 06, 2018 11:06 pm
Hi Andy, thanks for your answer.
I had read the description on page 2100 of the workshop manual, but it also describes handles and tweeters that I do not understand what they center with the chrome strip that frames the roof.
However are described some fir three fastener.
It would help to see how the parts are made or to talk to a coachbuilder who has already changed one.
Thank you for help.
Gabriella
