C.A.T.S Suspension
Posted: Sat Aug 26, 2017 3:38 pm
by DREW
I have been looking for a replacement X308 and have seen one which looks like its worth a viewing.It has CATS suspension which is a bit new to me.
A-What is it
B-Are there any issues i need to know
Its a 2001 sport 90,000 miles with service history mainly main dealer
DREW
Re: C.A.T.S Suspension
Posted: Sat Aug 26, 2017 11:54 pm
by PeterDavisX300
Computer Active Technology System.................For the suspension. I thought that was only on the Supercharged models and the LWB Daimlers? I also thought it was only on the US models? It's the 'Air-Suspension' stuff controlled by computer. Probably quite complicated, and expensive to replace. I have seen somewhere that a car with this type of suspension needs to have it replaced like-for-like because it won't run with the standard suspension. Not too sure?
Posted: Sun Aug 27, 2017 12:36 am
by davidr
This isn't air suspension - that was on the later X350.
CATS is a system of computer controlled variable rate dampers that can change the damper rate on each corner to improve road-holding, flatten out cornering etc whilst still having the Jag ride quality. On the 308 you will still have conventional coil springs. The same system was also used on XK8/XKR of the same period.
Posted: Mon Aug 28, 2017 5:20 pm
by Andy P
Hi Drew,
Computer Active Technology Suspension (CATS) co-ordinates the best possible balance between ride and handling by analysing road conditions and making up to 3,000 adjustments every second to the suspension settings via electronically controlled dampers.
If you would like a more detailed explanation I can send you an in depth PDF on the system fitted to the 2001 XK Range,PM me your email if you would.
I think there is quite a difference on price if you have to replace them at all compared to the non CATS shocks.
Happy hunting anyway for next X308.
Take Care.
Oh by the way don't forget to check the MOT history if you have the reg No,can save you a wasted trip.
https://www.check-mot.service.gov.uk/?_ ... 1503085139
Posted: Mon Jan 08, 2024 6:28 pm
by Davidqhog
Hi Andy,
I know this is a very old thread but I'd be interested in the PDF on how CATS works if you still have it!
As you know, I have a Daimler Super V8, 2001. I've been wondering if it has CATS as the sales book I bought a while ago suggests not. How can I tell and also, how can I tell if it's working?
TIA,
DQ
Posted: Mon Jan 08, 2024 9:07 pm
by ptjs1
DQ,
If you have CATS fitted, there are electrical connections on the top of the shock absorbers inside the engine bay.
I thought all Super V8s had CATS?
Posted: Tue Jan 09, 2024 11:09 am
by Andy P
Hi David,
Here is the link to the CATS pdf:
https://drive.google.com/file/d/1MOWuZy ... drive_link
Feel free to download the file.
Hope all is going ok.
Take care.
