Advice if engine flooded: method 1 and method 2!
Posted: Sat Nov 24, 2007 7:18 pm
Earlier this week I fitted a new photochromic mirror and when testing it I had the ignition on but did not start the engine: result = flooded engine. In talking to garages, I discovered that the V8s are apparently prone to flooding, particularly when not driven sufficiently far to get the engine to normal operating temperature. Apparently a frequent cause is people pulling the car out of the garage and switching the engine off while they close the garage door...
Method 1 was recommended by a well-regarded independent Jaguar specialist and goes something like this:
You need two people and one of them needs to know where the two fuel pump fuses are
Person A pulls the fuses and person B turns the ignition key
When the car starts Person A puts the fuses back in
The fuel starts flowing again and away you go.
if you have a trusty friend to hand, this may involve a delay of ten minutes or so to the start of your intended journey.
If you don't know where the fuses are or don't have a friend to hand then you need to get your friendly rescue service to tow you to a garage who knows these cars and can do it for you.
This is likely to lead to major surgery on your diary for that day.
Method 2 was recommended by a well-regarded Jaguar main dealer and goes like this:
Turn the ignition to position 2 (I think) so it runs through its system check.
When all the lights go out, floor the accelerator and turn the ignition to position 3
There will be a puff of smoke from the exhausts and the car will start
Apparently this counter-intuitive method works because if the accelerator is floored the injectors are cut off. I'm sure someone can provide a more technically accurate description.
I tried Method 2 and the car started within one second. It made my day.
Now because Method 2 is so easy, there must be a catch or Method 1 would not exist as it's too time-consuming and needs another person. If this problem occurred in the evening in a train station car park are you really going to ask a passing stranger to pull and replace a couple of fuses for you... or to floor your accelerator...
Posted in a spirit of community as you may, like me, be about to drive to the station and park up for a day full of business meetings in London and a non-starting car would seriously screw up your day. But also posted in the expectation that someone will enlighten me/us as to the benefits of Method 2!
I have of course learned not to do a system check without subsequently running the engine...
All the best,
Nigel
All the best,
Nigel
