Receiver Drier - Seals
I have a leaking receiver drier in my 2000 X308 XJR. A new drier isn't a problem but I can't seem to find which seals are required. Can anyone point me in the right direction? Many thanks!
Re: Receiver Drier - Seals
Just to answer my own question after some research - Jaguar no longer stock some of the required o-rings, and they no longer have the information on where each o-ring is used anyway. The solution was a bunch of generic o-rings and sensible guesses as to which fitted where.
2000 X308 XJR
2009 X-Type 2.2d auto estate
Good result, if possible post a link to the source of the O rings in case others look in future.
XF Sportbrake 2020 / XK8 1998
Sadly I can't take credit for the work or guesses as to which O-ring went where. The job was done by a local Jag specialist and he sourced a generic pack of O-rings from ebay. Still, all holding up well so far, so I'm pleased with the result.
2000 X308 XJR
