hand brake
Moderators:robv12, DavidEm
steveandtina
hand brake
Postby steveandtina » Mon Aug 01, 2011 11:38 am
:roll: is it just me or are all 308 hand brakes useless.might as well just put lollypop stick under front wheel.have to realy pull hard on it to hold on hill then if missus gets in she cant get it back off ps had car 5years and allways been like this. thanks steve.g
bmc123
Re: hand brake
Postby bmc123 » Mon Aug 01, 2011 10:37 pm
Is yours a manual? A bad handbrake is usually down to lack of use on the automatics - but a bad handbrake will fail the MOT so it can't be that bad? Maybe you need it adjusted or new shoes fitted? My car failed its MOT because of it so i am all too aware of it now :shock: New shoes sorted that problem out :mrgreen:
joejag308
Re: hand brake
Postby joejag308 » Tue Aug 02, 2011 12:14 am
make sure the central swivel on the cable is free and working both sides... :mrgreen:
robv12
Re: hand brake
Postby robv12 » Thu Aug 04, 2011 12:09 pm
if it is a 308 it WILL be an auto, I would check, clean and adjust and if needed replace the handbrake shoes, this cures most problems
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
