Cosmetic changes to brakes/discs - sacrilege?
Posted: Sun Apr 05, 2009 11:32 pm
by blackflash
Hi all,
I skimmed an article recently about the XJ8 in Jaguar World but didn't read in detail. However, I did see a mention of Brembo brakes which I took to be an option. Surfed the web a little and it looks like an expensive option both to fit and maintain. I have a soft spot for Brembos as I had them on a Fiat Coupe Turbo once and they saved me from joining an outside lane multi-car shunt...
Separately, I have noticed a couple cars (inc a Porsche) with red brake calipers looking very fine. Didn't notice whether the discs were drilled, slotted or whatever.
I'm broadly happy with the performance of my standard brakes on the XJR so I can't imagine laying out a fortune for a reto-fit of the Brembos. But I want my car to look subtly sporting - without adding boot spoilers etc. Would red calipers on a (black) sports saloon look ridiculous, or cheap and tarty, like a boy-racer's souped up Nova? I'm sure it's not a big job to have them sprayed if desired.
Similarly, drilled or slotted discs. Has anyone tried these and found any difference in performance? Do they look smart or naff?
This is all academic right now as I have other things to spend my money on but I like to plan ahead...
All views gratefully received, even those saying it would be sacrilege...
Nigel
Tarting up
Posted: Mon Apr 06, 2009 7:42 am
by joejag308
Nigel, the standard brakes on an XJR are higher rated anyway above stock. If its looks you need with "red" calipers ect the best way forward is to look in the "bling" sites and customising sites for plastic clip on items or special caliper paint and then do a cleaning job on your calipers then either paint them or add the plastic covers .....one item i was told about was " use green stuff pads" they give out less dust and do improve your braking slightly.
Brembo is an expensive alternative,not just with the initial layout of cash but any replacement of pads or discs are also expensive......for not much improvement or very little anyway (sorry Brembo fans).
As far as Jaguar and more so Daimler getting extra bling for their cars is quite hard as Jaguar protect the leaper logo very seriously.
Adamesh do quite a bit of "bling extras" but these are mostly USA stuff i have had a few bits myself......(im a secret blinger).........Joe
Posted: Mon Apr 06, 2009 10:15 am
by blackflash
Thanks Joe. I had thought about paint but not covers.
However the very mention of the word "bling" is enough to make me turn and run as that's the last look I want!
Any non-Jag-owner who knows anything about Jags knows how to tell it's an XJR - the grille and the boot badge being the most obvious. But otherwise the car is beautifully understated with clean balanced lines etc and still gets loads of positive comments. The performance is of course anything but understated and to me the combination of subtle looks and sheer power says "dark horse". Which is nice.
If red brake calipers would look bling then I risk losing one half of the dark horse equation so I'm going to have to think hard about this...
All the best,
Nigel
looking good
Posted: Mon Apr 06, 2009 5:19 pm
by joejag308
Nigel all power to your elbow mate ........im talking more personalisation than out and out bling bling..........simplicity itself can be a very worthy statement.......the sporty look on an XJR is indeed a fine look in itself.
If you think red calipers are for your car thats the way to go.......i love nothing more than seeing you guys with your cars at shows ....the detailing and finishing standards are a joy to see..........you dont have to be part of any concorse or pride and joy to look good.
Thats why the 308 forum stand has always the best selection of cars at any show.........come on down and have a look.......Joe
Posted: Tue Apr 07, 2009 9:05 pm
by ari1501
Nigel,
no, please no red calipers
. Instead you might be interested in the Black Diamond drilled and grooved disc set. I have one of these installed and they add the extra bit of looks to a sporty car still being discrete. Very good quality set, but unfortunately cannot truly verify if they'd be more effective in every day driving. Nothing to complain, though.
Cheers,
- Ari -
Drilled and grooved discs
Posted: Tue Apr 07, 2009 9:36 pm
by blackflash
Hi Ari,
Certainly the caliper covers are a non-starter. They're a joke even amongst Nova-drivers (I did a Google search) AND you have to unglue them if you need to change the pads!
Painting the calipers seems to be at least as popular an option but it's fiddly and they need cleaning regularly. Those who don't want to look too flash avoid red (and blue and yellow - yes, they are all out there) and go for black which basically just tidies them up. So it's probably black or nothing - at least until the next time I see that 911 with red calipers in the train station car park...
I would be really interested in seeing photos of the discs when fitted to an X308 - any chance you could post one or two?
All the best,
Nigel
Posted: Sat Apr 25, 2009 8:45 am
by ari1501
Hello Nigel,
finally got something uploaded - click link below:
http://www.flickr.com/photos/ap_shared
There are six photos, which are not that good as my car is still under some "surgery" inside the garage and daylight photos were not possible now. You can click individual shots open and then enlargen them into their original size.
Anyway, I hope they give you the idea.
- Ari -
Posted: Sun Apr 26, 2009 10:12 pm
by blackflash
Thanks Ari,
They look good.
Re: Tarting up
Posted: Sun May 17, 2009 10:07 am
by u102768
According to his signature, Nigel's car is a '98 so will probably have the same discs as the standard car as the discs were the same across the range then(305mm).
The XJR got larger discs in 1999 (325mm).
Posted: Sun May 17, 2009 12:08 pm
by blackflash
Yup, it's a '98. Hadn't realised there had been a change, thanks for that.
Posted: Sun May 17, 2009 5:09 pm
by joejag308
Phew didnt realise that thanks for that info......u102768
im glad mines a 1999..........Joe
