XJ8 Front wheel bearings
Posted: Tue Oct 14, 2008 11:56 am
by petticd
Hi, can anyone tell me the correct torque setting I should use when tightening the ABS Rotor nut after replacing the front wheel bearings?
This is for an early 1998 XJ8, in case there is a difference to the later ones which use a different bearing. Regards,
Posted: Tue Oct 14, 2008 7:02 pm
by jagtech
Hi the torque setting is 300 NM so get a big vice and a bit torqu wrench
sounds like you have done the hard part of the job if you have got this far
