J-gate lock up
Posted: Fri Apr 30, 2010 9:06 pm
by MTDJAG
HI, what are the possible causes for having the J-gate locked in park? Brake is pressed and brake light comes on but still not possible to move the lever. Any suggestions?
Posted: Sat May 01, 2010 9:05 am
by Brakebuster
there is a solenoid in the J-gate that fails
remove the ' star ' stud on top of the J-gate, insert the key to release the solenoid manually
not too expensive to replace
Posted: Tue Jun 01, 2010 9:49 pm
by MTDJAG
Great to know, thanks! but how is the solenoid replaced by just removing the star stud on top of the J-gate? is it not necessary to remove some of the assembly around the shifter to get access to the solenoid?
Thanks in advance for clarifiation :)
Posted: Tue Jun 01, 2010 10:06 pm
by Brakebuster
erm....... you kinda missed the point ?
you remove the star stud to over-ride the interlock so you can get home, etc
to replace the interlock , you have to remove the gear selector surround etc ,
Posted: Sun Jul 04, 2010 5:19 pm
by robv12
can also be a failed brake light switch
Posted: Mon Jul 26, 2010 4:05 pm
by MTDJAG
Hi again, thanks for all responses. Consequently to the first failure of the J-gate lock up, now also the electric mirrors, interior and boot lighting has failed. It seems the issue is the Body Processing Module which I now need to replace... :(
Posted: Mon Jul 26, 2010 5:37 pm
by robv12
stand a good chance, I would suggest a scan of the car , you will need someone with Autologic, or Jaguar IDS to give you a full interogation
Re: J-gate lock up
Posted: Fri Jul 08, 2011 11:22 pm
by joejag308
Its possible too the old chestnut....a low battery/ or dead cell ......could be the problem too.......run some jump leads across just to try starting the car....
