Morning All,
Just recently, when putting the car into Drive, the normally smooth & quiet cabin is interrupted by a mild vibration that isn't there when the car is in Park or Neutral. I can feel it through the steering wheel and gear lever. It's not violent but I'm certain it wasn't there before.
As we get up to about 45 - 50 mph, there's a whine from the transmission. This disappears on overrun.
I know this is a MB gearbox and I had the fluid changed about 3,000 miles ago by a good independent Jaguar workshop. I don't know if the procedure included the kinds of things that a ZF fluid change would (filter, sump pan, etc).
I'm wondering about the torque converter (my X350 SV8 is currently at Bristol Transmissions for a TC replacement and gearbox rebuild so I'm really worried about the Daimler now!).
I'd like to check the fluid level but I haven't got the dip stick (yet).
Any ideas from anyone?
Many thanks,
David Q
Daimler Super V8, gearbox whine and vibration
Re: Daimler Super V8, gearbox whine and vibration
David Q,
As is always the case with these boxes, if you do a standard fluid change, you'll only drain a percentage of the total fluid contained in the system which has a T/C and oil cooler and pipes in addition to the fluid in the box.
I don't know the history of your car, but unless previous owners were absolutely diligent about the way and mileage in which they did fluid changes, you could still have quite a lot of old fluid and sediment sitting in the system.
Therefore, I would start by doing another fluid change. (You can choose whether to change the filter again or not). At least this way, you'll have a lower percentage of "dirty fluid" after a second change. You could even run that for 10 miles and then do a 3rd or 4th change. As your Super V8 uses a MB 722.6 box, the fluid is pretty cheap compared to the LT71141 fluid in the ZF 5-speed box.
In my 4-speed XJS ZF box, I do 5 oil changes as a simple fluid drain only pulls an absolute max of 30% of the total fluid.
So, just do a few more changes and see if the situation improves. That fluid is cheap, whilst a gearbox and T/C replacement is expensive, as I'm sure you know!
Hi Paul,
Thanks for that. I'll get it booked in after the festivities for a couple of fluid changes.
I know the T/C hangs on to a load of fluid so it will be a good idea to flush some more through. As an aside, the Jaguar SV8 that is having a rebuild had some detritus in the fluid that had probably come from the T/C which they think was beginning to break up!
As you say, fluid is cheap compared to a rebuild!
Thanks,
DQ
Thanks,
DQ
