Hello,
I am new to the forum and to the UK. As a foreign post-grad student I figured something quintessential British was needed in form of transport. So I bought an '02 XJ8 SE with 91' miles on the clock with full service history and seems very well taken care of. Having driven the car for a few days now I discovered today the occasional tiny delay in engaging reverse. The car shifts smoothly and no noises from the transmission.
My question is if this merits a transmission oil change or more? And if so if anyone knows a good specialist near Edinburgh that could do the job?
Thanks in advance
- Mathias
Oil change on gearbox
- RichardSEL
Re: Oil change on gearbox
80k is the recommended mileage for Automatic Transmission Fluid and Filter change.
Previously there was no mileage published -- in common with other motor manufacturers Jaguar were saying "It's filled for life, sir!"
Don't know any independent Jaguar specialists in Edinburgh, sorry
I read that, very strange. Thank you for the respons, will try to find a garage that can do it80k is the recommended mileage for Automatic Transmission Fluid and Filter change.
Previously there was no mileage published -- in common with other motor manufacturers Jaguar were saying "It's filled for life, sir!"![]()
If the gearbox has never been done before, then it definitely needs doing. 80k may have been appropriate when the car was new, but even then I would suggest that 60k was the right figure. Even ZF who made the gearboxes said that 70k was the limit. I would recommend that the boxes in an x308 need doing every 40k max nowadays.
I'm sure Rob Jenner will be along soon to give you the name of a good independent garage near Edinburgh!
As far as I know it has not been done. Fantastic, want to have it done by someone with experience.If the gearbox has never been done before, then it definitely needs doing. 80k may have been appropriate when the car was new, but even then I would suggest that 60k was the right figure. Even ZF who made the gearboxes said that 70k was the limit. I would recommend that the boxes in an x308 need doing every 40k max nowadays.
Thank you Paul
- Mathias
