Hi Guys
I wonder if anyone can help with a problem i am having with my newly aquired 2000 XJR.
When driving, engine has cut out, both amber and red warning lights are lit and the following is displayed in sequence
Low Brake Fluid
ASC not available
Gearbox fault
Engine Failsafe mode
Engine will not start again for some minutes (usually 5-10), if ignition is tried, rev counter flicks up to aprox 1000 rpm then returns to zero and the above faults are once again shown on the dash display.
This has now happened 5-6 times, does not seem to be weather related as car has died in both wet and dry conditions
New fault has now shown up yesterday, car cut out as above but this time was accompanied by the air con display showing ER and beeping three beeps then pause then three beeps and the windscreen wiper made a single pass across the screen.
Any help with this one would be greatly apreciated
Many Thanks
Pete
Electrical Problems ?
Elecrical Problems
Pete I know i go on about this, but once again have the battery checked for a dead cell, simplist options first,not to mention cheapest.
The technicle side is a no no for me but so many guys have these faults on the displays and so many are battery linked.
If that doesnt cure it get some pro help with diagnostic equipment.....Joe
HIDDENalan2jaguars
i have exactly the same problem with my car only it happens when i try to start the car. sometimes from cold and sometimes when hot if i leave the car for awhile it restarts with no problems. i have checked the battery using a drop test and have also replaced the battery but to no avail.if anyone has had similer problems and managed to find a cure then please let me know..............regards alan
this is a well known problem caused by a weak battery,
replace it with the right type and everything should clear up just nice
and a point about buying one.......
Get it from jaguar, it will be the right shape and type, and it will also be about £20 cheaper than buying one from Halfords and such like, i think they come in around the £60 mark
HIDDENalan2jaguars
HIDDENalan2jaguars
HIDDENalan2jaguars
my car eventully stopped working and even leaving the car overnight did not help so its off to an auto electricans in witham essex to hopefully sort out this persistant problem at least if the fault is constant it should help to locate this annoying little glitch.
p.s my other jaguar is a 1967 420 which is a piece of cake to fix regardless of the faults.so much for progress when even jaguars cannot sort out there own problems concerning their car electrics
