Body Processing Module and car-alam light dim/on
Posted: Sat Sep 08, 2007 10:40 pm
by MTDJAG
Background:
I had a very annoying problem in that the car-alarm light sometimes comes on or is dim/flickering. If this happens when the ignition is off, it can make the car impossible to start. If it happens when the engine is on, some strange things happens, like the windshield wiper comes on for one stroke.
The problems seems to be bad earthing as the car-alarm light comes on when the BPM is removed from the car frame. I can also get the symptoms above when I "wiggle" the BPM somewhat while in situ.
Solution:
It turned out to be a bad soldering on one of the two earth points on the BPM PCB. The BPM had to be removed, opened up and then the two earth points re-soldered.
Conclusion:
A very annoying situation which I had for 4 years w/o solution but is now resolved.
symptoms
Posted: Tue Sep 11, 2007 5:38 pm
by joejag308
I had identical symptoms, and it went away for a short while and then in Scotland it came back with a flat battery the solution was a dead cell in the battery...........so new battery no more problems!!
If you get a drop test done it finds the dead cell, some hand held gauges dont find the dead cells..........Joe
Posted: Tue Sep 11, 2007 10:35 pm
by Brakebuster
there are a host of problems and warning lights associated with a duff battery ,
even if you just borrow one to see if it all goes away ,,
but i bet you will find that everything will get better with a new battery ,
the Jag ones only seem to last five or six years ,
as said, normal voltage checks dont show a bad battery , you need a professional tester for this
battery
Posted: Thu Sep 13, 2007 5:27 pm
by joejag308
BB five years is good for a Jag battery....my car was purchased directly from an X Jaguar director who serviced it via a main dealer well in front of its mileage...but he had a new Jag battery at 12,000 miles and i have just had a battery fitted now at 30,000 miles (not a Jag one either) so its had two in 30,000 i had chance of a higer rated Lucas battery meant for a diesel........i would say that the electrics on the Jaguar are the same as the Daimler so the battery would need the same type. An important item we all take too much for granted....Joe
