Okay, My near side brake lamp has gone triggering the amber warning light on the dash every time I press the brake. The lights work okay but just not the extra illumination when braking. The bulb is working. I tried it on the other side. I also check the whole ensemble and everything is working so I'm guessing it may be wiring or, as I've seen online, a possible problem with the SLM. All the wiring looks in good order. Immaculate even but I still intend on testing them. I'm no big electrician so advice on how I might test the wiring to see if there is a problem would be appreciated... And, if its a problem with the SLM, what else might I experience if there was a problem? (My parking sensors have been playing up again lately as well)
Thanks in advance for any help
Brake Lights and SLM????
sshaunus308
Currently 2007 2.2 X-Type Sovereign, 2002 4ltr XJ8
Gone - Toyota Avensis
2002 Ford Fiesta
1999 Vauxhall Astra
1991 Porsche 944S2
1990 Nissan 200sx Turbo
1993 Vauxhall Calibra
2002 Ford Fiesta
1999 Vauxhall Astra
1991 Porsche 944S2
Re: Brake Lights and SLM????
Hi sshaunus308.
I would check the continuity of the wiring from the SLM to the stop bulb.Cable should be blue.
You can also check to see if there is an output from the SLM on pin No BT1-9 on the connector.
Have someone press the brake pedal and check the pin with a multi-meter.
If no output then the fault is most likely in the module.
BT1-3 is the pin No for the other side. It would seem you have feed to the SLM because the off side bulb works. Have attached a couple of diagrams which might help you.
The reversing sensors uses it's own module so that problem shouldn't be related.
The site will not allow PDF's so I can't attach the complete wiring manual.
If you would like the wiring manual P.M me you email address and I will gladly send you a copy.
Hope that helps anyway.
Let us know how you get on if you can.
Take care and stay safe.
sshaunus308
Hi Andy
Thanks. That's exactly the information I needed. That's my weekend sorted. I guess the parking sensors may just be due to slightly weak battery from the cold weather.
Thanks again for the info
Shaun
Shaun
2002 Ford Fiesta
1999 Vauxhall Astra
1991 Porsche 944S2
2002 Ford Fiesta
1999 Vauxhall Astra
1991 Porsche 944S2
sshaunus308
Update....
So I finally got around to checking the issue with my right left brake light. I checked it with a multimeter and the wiring seemed okay though I'm not entirely convinced I really knew what I was doing. Anyway, I'd, a few months ago, managed to get hold of another SLM for a decent price of ebay. Plugged it in and the brake light now works fine. Reprogrammed the keyfob and thus far, all is good...
2002 Ford Fiesta
1999 Vauxhall Astra
1991 Porsche 944S2
2002 Ford Fiesta
1999 Vauxhall Astra
1991 Porsche 944S2
Great news Shaun.
Glad you were able to get it sorted.
Enjoy your car.
Take care.
Enjoy your car.
Take care.
