It's on again...
Posted: Sat Oct 15, 2016 8:33 am
transferred from "New Arrivals"
Reprise:
"Back on the battery topic, having changed battery day before and done a run around in the heat and stop go traffic of rush hour the previous evening. So wasn't expecting any errors to come up on the display. But five miles down the A102 an EML came up with engine icon. 'Phoned both Sidcup and Sevenoaks service departments but neither could take in, even just for a diagnostics (one hour at £115 +VAT) until the following week. As there was no limp mode, between EML on and off, or any other changes, decided to go onto Newhaven with EML on.
Once there, a scan showed:
P0420 Cayalyst system efficiency below threshold (bank 1),
P1260 Security input./Theft detected, vehicle immobilized./Theft detected - engine disabled
P1111 System check complete
Had them cleared (£30) and they didn't return on the return journey except still the boot lid lock gives alarm wails if operated by key.
Had I known of the leaving "battery disconnected for 20 mins to cause a hard reset" (thanks, Mike, there was only five minutes of disconnect between batteries) could've saved myself worries and £30
VWs have a specific leaving the IGN on procedure for battery change. But didn't use that as didn't know whether that could upset Jag modules' coding. Read that there's a warning logged of the Security input type if battery's disconnected?
If it's left for 20 mins with battery disconnected, are default codes stored in module's loaded at battery re-connect. Or "last known state" codings loaded? Obviously some settings somewhere have changed by my changing battery. Are there settings (codings) that can be changed by user input by way of a scanner?
For example, on the '06MY Passat you're able to have low level indicators on all the time as a continuous DRL -- these can be switched on (and intensity) via either the dealer tool VAS or VAG-Com, aka VCDS.
and
"Drats. Despite the new battery and driving around including 22 mile trips the quick flash of error message at engine startup "TRAC NOT AVAILABLE" was seen just the once today. Happened when I started up without waiting for the diagnostics to display and icons to go out.
Since there's no effect on vehicle performance, will have to assume this is just a "feature". There was a lot of startups (four or five?) done moving car around today.
And after a visit to my favourite Albanian car wash. Though they do get a bit enthusiastic with their power washers
Reprise:
and
