Part Numbers for Centre Console Bulbs
Moderators:robv12, DavidEm
Mike1932
Postby Mike1932 » Fri Oct 02, 2009 8:34 am
Does anyone know the correct Part Nos for (a) the temperature display and (b) the AC/Auto bulbs for my 1998 X308?
I ask because the local Main Dealer has supplied the wrong bulbs to my Jaguar Specialist in the past - and I don't want to strip down the centre console only to find I have the wrong bulbs!!!
u102768
Re: Part Numbers for Centre Console Bulbs
Postby u102768 » Mon Oct 05, 2009 9:46 am
Unfortunately, there are three bulbs listed for the air-con control unit:
JLM 20308 - Indicator lamp - blue x 7
JLM 20309 - Indicator lamp - green x 2
JLM 11965 - Indicator lamp - LCD x 2
I will leave it up to you to work out/guess which one is which.
They aren't horribly expensive anyway so you could get a selection.
Mike1932
Postby Mike1932 » Mon Oct 05, 2009 1:48 pm
Many thanks u1 - joejag kindly ran a check with his local Jag Dealer and identified JLM11965 for the a/c display (2 required), JLM20308 and JLM 20309 (blue and green respectively) for the a/c switches. I need to establish whether my car has blue or green fitted, as I understand one bulb only illuminates the 'a/c' and 'auto' switches.
