Hi all,
as the standard radio/CD/speaker system lacks in sound quality, I have been toying with the idea of replacing the speakers in all doors with better ones. However, this may not be worth it, if I can't add an extra amplifier between the head unit and speakers.
My question is: Does the standard X308 radio unit have line out connectors or do I have to start looking for the optional premium sound system(Harman/Kardon) unit?
Cheers,
- Ari -
Radio head unit differences
there is a current thread deeply involved with installing the HK system,
its not a simple head swap, or amp install,
your existing head unit is actually quite an advanced piece if kit, and will actually deliver good quality sound, however the stock paper cone speakers do let it down, buy some good quality door speakers to drop straight in, and it will improve the range greatly
btw, welcome to the forum
BB, thank you for your reply.
Oops - didn't think of checking the "Accessories and Customizing" - I am in the wrong section/index with this, sorry!
I agree that replacing the Philips papercone woofers would make a difference, but it'd still leave a lot to wish for. I am not planning to do the H/K -conversion nor properly "pimping my ride".
As the standard head unit has a built-in amplifier, it probably hasn't got the guts to drive high quality units. I also feel I'd need the possibility to equalise the signal a bit and that's easier done with a line-level signal.
I read the thread about the H/K upgrade path. However, nobody refers to the difference of head units - so are they the same? After studying the electrical schemas the only difference is the speaker outputs(8 pins) in the std head versus the line outputs(6 pins) in the H/K head.
If the head units are the same, can someone verify that the std unit has line-level outputs in addition to the normal high-level spkr outputs?
Thanks again,
- Ari -
Thanks again,
- Ari -
1999 XJR - 7" LP, Quaife ATB etc.
blackflash
I have the full kit needed to do the H/K upgrade and it does NOT include a new head unit. However it does include an additional harness which runs from the head unit to the POWER AMP which sits in the boot over the standard six-CD stacker... and it's the power amp which gives you the oomph you need. It drives the sub-woofer mounted beneath the rear parcel shelf (there's an integral and visible grill in the shelf), the uprated door speakers (woofers), the uprated rear door tweters, and the front tweeters in the (special) A-posts which replace the ones in the front doors.
Just waiting until I have the funds ready to spend on the 1-2 days needed to fit it all... including removal of rear seats to fit the additional harness.
Hope this helps,
Nigel
Hope this helps,
Nigel
Blackflash
'05 S-Type R in Liquid Silver with Dove leather and Aluminium trim
Thanks Nigel,
as you say _additional harness_, it leads me to think the head unit has extra connector for this harness (or it is meant to replace the speaker output connector(s), which I doubt). Is the H/K amp input end of the harness equipped with a standard looking connector i.e. does it show anything "non-proprietary"(like Left front, Right front, Sub etc.)?
What I am trying to achieve here is - if I had the extra harness, could I connect an off-the-shelf modern amp to the head unit?
Cheers,
- Ari -
Cheers,
- Ari -
blackflash
I haven't seen the back of the head unit so can't help I'm afraid. But unless you're a hi-fi buff at home (I am, I'm afraid) I think if you could get your hands on a Harmon-Kardon power amp and the associated harness then you'd get a big improvement in your sound - and you know such concerns as connectivity would melt away too.
Do keep us posted on what you do.
Nigel
Nigel
Blackflash
the amp in the boot is fed from the back of the existing head unit utilizing the existing speaker and power output connector , this loom goes to the amp which in turn sends wires back to the head unit ( contained in the same loom ) to plug into the existing cars speakers loom ( that was plugged in to the back of the stereo)
the front door tweeters are replaced with a-pillar speakers that are already wired into the car,
the parcel shelf sub-woofer is wired directly to the amp
if a cd changer is installed in the boot, a link cable is plugged directly into the amp and not to the head unit
the linking loom that goes from the head unit to the amp carries all power signal and speaker connections for full control
Thanks guys,
this confirmed my worry - the amp end is also very Jaguar proprietary, so the best approach to a better sound would be finding the premium H/K set with at least the amp and harness. Unfortunately they are practically impossible to find here, but of course there's always eBay...
Thank you again for your help!
- Ari -
- Ari -
blackflash
Try Eric at Eurojag
If you are going to go down the eBay route then track down Eurojag there snd drop Eric a line. They don't get many coming through but I paid £100 for the H/K amp, sub-woofer, 4 woofers, 4 tweeters, harness... and even the parcel shelf and A pilars! Everything except the CD stacker basically. Hope this helps,
Nigel
Nigel
Blackflash
