XJR Coolant leak / Removing Supercharger!! HELP!!!
Moderators:robv12, DavidEm
geoffhanks69
Postby geoffhanks69 » Fri Jan 11, 2013 10:53 am
Hi All
I little while ago i purchased a xjr V8, and it has developed a slight leak.
It looks as if the leak is coming from the underside of the super charger, and running down between the back of the 2 heads!! I have purchased a technical manual for the car on a CD, but it doesnt give me an idea of where it might be leaking from. Are there any hoses that run between the 2 heads, under the super charger. Hope someone can help.
I have bought myself an inspection camera, but cant really see anymore.
Does any 1 know how easy it is to remove the supercharger!!!!
:cry: Many Thanks Geoff
skeltz
Re: XJR Coolant leak / Removing Supercharger!! HELP!!!
Postby skeltz » Thu Feb 14, 2013 2:56 pm
There is a water hose running in the v that goes soft & leaks, supercharger no t difficult to remove just a lot of work .
