Won't start when hot
Moderators:robv12, DavidEm
steve2650
Postby steve2650 » Sun May 16, 2010 3:46 pm
First of all please excuse any mistakes as this is the first time I have used any such forum. Can anyone help me with a problem on my 1998 xj8 3-2. It starts and runs perfectly from cold and if I do about 5 miles and turn it off it will re-start again without a problem, however if I do adout 10 miles or more and turn off it will not start and brings up the "engine fail safe mode" message. It will only re-start after being allowed to cool for some time, perhaps up to an hour or more. There does seem to be a lot of heat under the bonnet but the temperature gauge shows normal. I've checked the fuses for the radiator fans and they are both ok, the fans work but do not "run on" when the engine is turned off as they do on some other cars, I don't know if they should or not. I've tried a fault code reader and it shows "no codes". I've removed the coolant filler cap with the engine running (cold) and water appears to be circulating so I assume the water pump is ok. Sad
Any suggestions or comment would be appreciated.
Steve
daveji
Postby daveji » Sun May 16, 2010 8:24 pm
First thing I would do is get the thermostat changed.
It might be failing to open.
steve2650
Postby steve2650 » Sun May 16, 2010 9:45 pm
Thanks daveji .... I'll give that a try and I'll reply to say if it worked or not.
