my new xj8 cuts out !!!
Posted: Fri Oct 31, 2008 12:54 pm
by twin
i have covered only 85 miles in my 1998 4.0 xj8,
the following problem has occured twice at 70 mph ish on dual carraigeways. the car loses power then comes to a stop, on restarting it throws a lot of white smoke out of exhausts then is fine ??
Posted: Fri Oct 31, 2008 1:29 pm
by Brakebuster
this is a common problem for the early xj8's,
get your nearest Jaguar dealer on the phone and get them to run your VIN number to see if the throttle body modification has been done
i suspect not, they will book you in and give you a free upgrade to the latest throttle body
it is mentioned else where on this forum, hope this helps
Posted: Sat Nov 08, 2008 4:06 am
by twin
got car back new throttle body fitted............ and running like a dream,
jag at peterborough are top men...... even washed it and hoovered it...
throttle body info
Posted: Sat Nov 08, 2008 3:26 pm
by joejag308
I didnt know about the info......so i rang Minster Jag in Leeds with my vin no and they comfirmed it had been done in 2003 At Morrits Jag main dealers via Jaguar......... :wink: ......
Nice to know these things...........
Posted: Sat Nov 08, 2008 7:05 pm
by Brakebuster
twin....good news,
nice to know that not everything associated with these fine motors costs lots of money doesnt it, lol
Joe,, didnt know yours was an AJ26 engine, must be pre 1999.....?
mines a post 1999 ( 2000 model year ) and i have the electroniic throttle body on the AJ27 engine...so no need for this particular mod to my version of the X308
BB 8)
AJ 26 engine
Posted: Tue Nov 11, 2008 8:22 am
by joejag308
Nither did i until you just mentioned it....... :lol:
Posted: Tue Nov 11, 2008 6:12 pm
by Brakebuster
lol
the main differences from the earlier AJ26 engine to the later ( post 1999 cars to 2002 ) AJ27 engines are
electronic throttle body instead of the vacuum advance device on the side of the TB ,
4 pin spark-plug coil packs in place of 2 pin coil packs,
different engine management system and engine loom,
VVT ( variable valve timing ) in place of none ( 3.2 or 4ltr )
different cam covers and seals ( more of them ),
2nd generation timing tensioners as standard ( still the same problems though ),
different engine covers ( transverse moulded strip rather than a linear moulded stripe with the V8 legend) with some more cut-outs up front
just to name a few
8)
Re: my new xj8 cuts out !!!
Posted: Tue Aug 28, 2012 8:38 am
by dwg397
My 7/8/1998 reg 4.0L has VVT. Vin No 851090. Does this mean it is a 1999 Model? Interesting to see the differences between 26 & 27. Yesterday had to be trailered home due to cut out. Fault code 1596 on mechanics code reader, VVT control B. The throttle body has been replaced by Jaguar. After fiddling with various connections including the main ECU, car started! Mystery remains. Got to pluck up courage now to take it for a drive!
Dave
Posted: Tue Aug 28, 2012 9:04 am
by Brakebuster
well,
it could be anything, when and were does it cut out , at speed ? at idle , at traffic lights etc
the main causes are sensors of some kind,
try the MAF sensor on the air intake tube, also check that tube for any splits at all , as this will imbalance the fuel injection
also the small tubes coming from the top of the cam covers, these are the full load and part load breathers, if these are split or blocked it will also cause running problems ,
you VVT control B is the right bank while sat in the drivers seat , the VVT unit is inside on a '26 engine, and outside on the front of the cam cover on a '27
ensure you have new oil in the engine, as the VVT run on oil pressure, and if the oil is dirty or to thick it will cause problems ,
hope this helps
Posted: Sat Sep 01, 2012 10:12 pm
by dwg397
Hi BB,
The stall happened on approach to a roundabout on slowing down. The code should have read 1396. Oil should not be an issue as the car was serviced 100 miles ago. It would appear the engine is a 27 as the VVT unit is on the outside of the cam cover.
Thanks for your interest.
Kind regards,
Dave
Posted: Mon Sep 10, 2012 7:04 pm
by dwg397
Just as a follow up to my stall problem. It seems that the fuel pump in the tank had failed. All is well at the moment.
Dave
