need a quick answer
ello there, just a quick query.i had my tensioners done a couple of weeks ago.(3rd gen).i have noticed the engine is a little more noisy!? compared to before. is that normal? or is it a trip back to the garage!!!!! cheers robo
one love!
NOISY ENGINE
Robo if you are unsure in your own mind don't hesitate take it back, after a job like that you need to be comfortable with it.
Only the guy who did the job can reassure you........Joe
i agree..
bear in mind there are a few other items under the bonnet that will make a noise, and get noisier with age,
these are , but not limited to...
the fuel injectors, they get a louder click with age,
VVT solenoid on the front of the engine, get loud as it wears
jockey pulley for the serpentine belt, there are two, one on the tensioner, and a free wheeling one by the alternator, its usually the second one that goes , easy swap out , i just did mine
did it have a full oil change after the work ? if not, i would get one done asap......and ensure the right grade oil is used 5W30
i bet you have been listening intently since the work, and are noticing noises that were already there , but not prominant in your mind ?
hope this helps
hope this helps
cheers lads
cheers dudes,the mechanic did say about having a oil change when he done the swop.and it is very true im listen to the engine even to the extent of not puttin any music on!!!! he has done a fair old few of t.t swops for club members and other jag owners on the island so i think he should of put everythin back in right! cheers for your replies and ill keep you informed.
one love!
