XJ308 4 litre year 2000 cylinder numbering
Moderators:robv12, DavidEm
catsclaw
Postby catsclaw » Tue Sep 11, 2018 2:39 pm
Good Afternoon,
Can anyone in the club tell me the cylinder numbering and locations for the XJ 308 V8 4litre year 2000 engine? I do not require the firing order but the actual number and location of each cylinder. In particular I would like to know where cylinder 6 is and the associated coil F?
As you've probably guessed I have to replace the coil on that cylinder and wanted to get a heads up from those with more knowledge than me on this matter before I dive in and do the work.
Thanks for reading AJW
Andy P
Re: XJ308 4 litre year 2000 cylinder numbering
Postby Andy P » Fri Sep 21, 2018 9:48 am
Hello AJW,
Sorry I missed your question earlier on but I hope this helps.
The right side cylinder bank is designated as "A" bank,and the left side as "B" bank.The cylinder bores of each bank are numbered 1 to 4,starting from the front.
References to the left- or right-hand side of the vehicle are made as if viewing from the driver's seat.
With the engine installed in the vehicle, the right-hand cylinder bank is designated Bank A, and the left-hand cylinder bank is designated Bank B.
Good luck.
Take care.
Andy :D
catsclaw
Postby catsclaw » Fri Sep 21, 2018 10:21 am
Hi Andy,
Thanks for your reply. I've got the coil and aim to fit it this weekend. Lovely looking sovereign you've got there Andy.
Happy motoring.
Kind regards,
Ashley
