Inspecting timing chain tensioners
Moderators:robv12, DavidEm
XJ_Driver
Postby XJ_Driver » Wed Oct 12, 2016 8:33 pm
I'm planning to remove one of the cam covers from my 2002 XJR to see whether I have the latest timing chain guides fitted. The LH (nearside) cam cover looks to be the easiest to remove. Apart from a new LH cam cover gasket, any other materials I should need to have ready for this job?
I'm just checking which tensioners I have fitted at this stage, so only R&R the cam cover.
Many thanks.
John.
Best regards,
John.
2003 XJ8 3.5 SE
1979 XJ3.4 Se.2
Re: Inspecting timing chain tensioners
Postby J44EAG » Wed Oct 12, 2016 9:17 pm
Brake Busters excellent illustrated thread here shows the complete job in progress as regards the top secondary timing chain TENSIONERS rather than the primary drive chain guide which is behind the front timing chain cover plate. I`m assuming that you might mean tensions rather than the primary chain guide?
http://www.jec.org.uk/forums/viewtopic.php?f=86&t=3324
Check to make sure that the seals are working and the spark plug wells are not full of oil (leaky spectacle seals) or water which can be down to condensation or other water ingress. Coil packs, rubber boots and plugs don`t like being immersed in liquid!
XJ_Driver
Postby XJ_Driver » Thu Oct 13, 2016 9:52 am
Thanks for that Mike - appreciated!
Don't know why I typed 'guides' - I was thinking tensioners...
Cheers,
John.
Best regards,
John.
2003 XJ8 3.5 SE
1979 XJ3.4 Se.2
robv12
Postby robv12 » Thu Oct 13, 2016 11:22 am
to be honest, removing the cam cover is the most time consuming part of the job, once your are in there the swap is a 10 minute job, bear in mind you then have to put it all back together again and then take it all apart once more if you decide to do the job, OR have the car immobile while you are waiting for parts, just my take on it, for the cost of two top tensioners I would just do the job at the first shout
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
Postby ptjs1 » Thu Oct 13, 2016 1:58 pm
John,
I have taken the liberty of changing the title of the thread to read "tensioners" in order that this will assist other members using the "Search" facility, I do hope this is ok with you.
XJ_Driver
Postby XJ_Driver » Thu Oct 13, 2016 9:40 pm
Thanks Paul - no problem.
Food for thought there, Rob. I hadn't considered the job in that way before. Engine running fine at present, so perhaps I'd better get the parts and tools together, clear some space in the garage and book myself a weekend to get on with it!
Thanks again.
John.
Best regards,
John.
2003 XJ8 3.5 SE
1979 XJ3.4 Se.2
RichardSEL
Postby RichardSEL » Fri Oct 14, 2016 8:28 am
Don't know why I typed 'guides' - I was thinking tensioners... Cheers, John.
Perhaps coz there's two ways to skin this cat's design fault?
Surry Jags quoted me £521.12 for the top chain tensioner upgrade to the metal 4.2L V8 AJ engine type; while change out of top, bottom, guides, and chains costs £750
Thanks to Brake Buster for his excellent illustrated thread :idea:
I now know what I'm buying...
robv12
Postby robv12 » Fri Oct 14, 2016 9:57 am
my suggestion is this
I get my top tensioners from Neville at NE Jag Spares, you will see they come with upgraded bolts
http://www.jaguarspares-northeast.co.uk ... 11-c2a1512, it is unlikely the chains will be damaged, but if they are Neville has these as well, but two cam cover gaskets as well.
hire the tools from Annie Jenkins
http://www.ukjag.org.uk/
then you are set to go, allow an hour each side, add a little if it your first time, but it really is a very simple job to do,
While you are in there you can see the lower slipper guides, these can crack, but and this is the but, the lower chains can't go anywhere , whereas the top ones can and do fall off the worn and/or broken tensioner wrecking the engine. I ran a Super V8 with a "wobbly" bottom chain for ages , it ran fine just sounded a little "chainy"
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
