I found this out on my Sport when I left on the pax map light (switched off a day later) and finding out that the stuff in my glove box was allowing it to shut but not switch off the internal bulb (found out a further day later)
Add to those having only done short trips for the previous fortnight and there was the battery's charge state.
The symptoms were engine turning over with the occasional fire but then no fire -- repeated
Eventually tried starting with a jump -- the same symptoms with engine turning over faster
A check with my ISoft did not show any fault codes stored. A hard reset disconnecting the battery -ve overnight didn't help either. The -ve lead to body work chassis was noticeably warm from the large amounts of start current being delivered. For later attention
Eventually, removed air filter from top to expose the butterfly valve. And gently opened it about a ¼ and wedged it open. Tried again to start and five or six of the eight fired and then stopped. Figuring I might've now burned off any flooding in the cylinders, replaced the air filter junction and tried starting again. This time five or six of the eight fired up. Tried three or four more times and eventually those five or six of the eight fired and stayed running with the seventh and eighth later joining in. Took for a 22 mile run down the motorway and back and all was well
Had a long run scheduled and the performance was back to its usual excellent self -- starting on the button with 26 MPG mixed mode.
Plugs had been changed about 12k miles ago, as was air filter.
Battery's a Bosch S5008 one year old but only the 70AHC version
Realise there's probably a more sophisticated way to clear flooded cylinders than the above (which has probably had the v. knowledgable techies in here cringing
