4L V8 Sport ?.
Moderators:robv12, DavidEm
springelec
4L V8 Sport ?.
Postby springelec » Sun Apr 26, 2009 1:28 pm
Hi Everyone,
Whilst there are quite a few 3.2L V8 Sport XJ8's about, there are very few 4L, V8, Sport XJ8's.
Why is this ?.
I've realised that the 'Sport' has an XJR grill and less chrome.
These differences are obvious.
But are there any more useful and interesting details that separates the 'Sport' from say the 'Executive' or the 'Sovereign'?.
And if these cars exist, why isn't there one pictured above in the 'Models' section ?.
I like the look of the 4L, V8, Sport's I've found on the internet, but can't make up my mind whether to plumb for one of these or an XJR.
Any information and advice will be gratefully received.
Springelec
Postby Brakebuster » Sun Apr 26, 2009 3:38 pm
i'm afraid you have been miss-lead,
Jaguar didnt make a 4ltr ' Sport ' ,
the ' Sport ' was only made in 3.2 guise , the 4ltr was held for the Sovereign, and the Executive , of which you could have a 3.2 if you wished ,
anyone calling an 4ltr XJ8 a ' sport ' is lying, or has been sold a car with the wrong description
the XJR is a totally different beast, and in V8 form has a supercharger.....
hope this helps
joejag308
which model ?
Postby joejag308 » Sun Apr 26, 2009 3:40 pm
Welcome "spring alec"........its down to personal choice either cost , quality,sports spec, or comfort that you wish for....a lot of people automatically think "sport" means its a flying machine....they all are if you want them to be.........obviously the 4Ltr is a larger engined model compared to the 3.2 the XJR is a supercharged 4ltr the main differences are the interiors, the Sovereign, is the top Jaguar spec and the Daimler Super v8 is the very top spec..........have a look at a few different models
you do have a perfect opportunity at Thorseby Hall at the anniversary show on the 7th of June there we will have a complete selection of 308 models for your indulgence .........while you are in this forum take the opportunity to ask for the things you need to know before you buy a 308.
It could save you a few quid.........there are indeed pitfalls....so use the forum.......its free........Joe
springelec
4L Sport
Postby springelec » Sun Apr 26, 2009 4:14 pm
Thanks Joejags & Brakebuster,
The Thorsby Hall event does appear to be the ideal opportunity to view several models.
However, by way of example, Freemans Of Sevenoaks Limited have what they describe as a 4L XJ8 Sport ?.
It's blue and is a good example of the type of XJ I'm after, although not this actual car because it has too many miles under its belt.
It can be viewed either directly on their web site or via Autotrader.
Can you clarify ?.
Springelec
Postby Brakebuster » Sun Apr 26, 2009 5:28 pm
the car in the advert is deffinatly a ' Sport ' , as the front grille is colour coded and the ' upper environment ' window trims ( as Jaguar call it ) is in black rather than chrome, the car has the ' XJ8 ' badge indicating its a baseline model,
i would have thought someone has added a few ' extra's ' in its life
as the half wood steering wheel would be an option, as would the stainless mash grille inserts, they are from an XJR ,
the car is described as having a heated front screen, i would doubt this, but its not impossible, and it doesnt have cruise, or wooden surrounded switchgear,
i'm not saying its a bad car, but i would request the VIN and get it decoded to ensure the engine is correct,
also , the 98 Sovereign they have for sale is overpriced at £5.5k, even with 54k miles.......
hoppe this helps
btw, i own a 4ltr XJ8 Sovereign :wink:
springelec
4L Sport
Postby springelec » Mon Apr 27, 2009 10:51 am
Okay, Okay, I admit I'm a bit clueless about the details of XJ's, but I know what I like and that's the XJR look.
I like the stainless mesh grill and the colour coded grill surround. I also prefer the black/colour around the windscreen and the half wood steering wheel and the extra wood around the cabin.
So apart from the obvious, i.e. get an XJR, what other 4L model should I be looking for to get all these extra bits ?, (if it exists.)
Springelec :-)
Postby ptjs1 » Mon Apr 27, 2009 12:14 pm
Springelec,
I think you've got two choices. Go for an XJR or start compromising &/or customising.
An XJR is a significantly different car to drive - significantly quicker than a normally aspirated car. Also, some XJRs are spec'd up with crome window kits etc!
If you decide to got for a n/a 4 litre (which is quicker and more economical than a 3.2) then you've got a dilemma. If you want the toys - wood switch packs, cruise, electric steering wheel etc then you'll need to go for a Sovereign. And it probably still won't have a 1/2 wood wheel. But you'll still have to change the grilles and surrounds. And you'll have chrome around the windows and screen.
If you want the "look" - black window surrounds and grill etc then you won't get a 4 litre or the toys.
So if you want a 4 litre (you do!) and all the toys and it's not an XJR, I think the best you can do is get a Sovereign, change the grilles and live with the chrome. Or get a standard 4 litre XJ8 which has been spec'd up with cruise etc (it's not standard), add some 2nd hand switch pack woods, change the grilles and at least you'll have less chrome around the side windows. But still you won't have electric steering wheel and stability control etc etc....
I guess everything in life is a compromise, unless you have a lot of money!
Good luck with your choice!
Postby Brakebuster » Mon Apr 27, 2009 1:49 pm
as Paul says above
if its the ' look ' your after,
then you have to get the ' sport '
with its black window trims and colour coded front grille surround and ' sport ' seats but a 3.2 V8 engine, it will also be lowered very slightly with stiffer suspension.....
all and any of the other extra's like cruise control, wood switch surrounds ( standard ones are plastic ) electric adjust able steering wheel, heated seats , 6 cd changer heated front screen,cup holder armrest , steering wheel telephone controls , electric adjustable headlights ,folding chromatic door mirrors ,half wooden steering wheel and full electric seats will be a bonus if included , but not on the original spec of a 'Sport'
if you dont mind the chrome window surrounds ( they dont actually rust like the black ones can ) swapping the front grill is a doddle, and would cost no more than £50,
there are NO other body modifications between the spec's , not even spoilers........
like isaid above, i'm not tring to put you off in any way shape of form, but letting you know what the differences are , as not a lot of peeps know without a lot of research , and then are disappointed 'their ' car doesnt have such-n-such a feature
if you dont mind not having a warrantee , then private with lots of history is the way to go
4560max
xj 8 4ltr
Postby 4560max » Mon Apr 27, 2009 7:21 pm
hi ihave 1999 xj8 with a 4 ltr engine it is black with black grill and sport suspension .it is registerd as such on the log book .so idont know what i have got if they did not make this model. when i was looking for some tyers they wanted the reg and it came back as a xj8 4ltr A R C model i dont know if this means anythingh or not?? the 4 ltr is a lot better car to drive than the smaller engine and not as fierce as the xjr which is far to fast 4560max
springelec
4L Sport
Postby springelec » Mon Apr 27, 2009 9:20 pm
Thanks everyone for all this info, I really appreciate the help.
I've been looking today at 3.2L Sports models and I've identified three that look stupendous and are very reasonably priced.
However, the killer is performance.
The X308 is a BIG car and I'm a little concerned the 3.2L is going to struggle.
Is that fair ?, or am I being unduly pessimistic.
My reference is my Yr 2000, XK8 which is a really nice car to drive when I can prize it from my wife !!.
XK8's are similar in weight and the gearbox is probably identical to that fitted to the XJ8, but it has the advantage of being fitted with a 4L engine.
I've also found a nice Yr 2000 XJR with 82000 miles, but the three Sports are all 50K - 60K.
I'm not sure which way to jump, so keep your opinions pouring in.
Eventually I'll make a decision ! !
Springelec
Postby Brakebuster » Tue Apr 28, 2009 7:22 pm
you seem spoiled for choice, lol
the 3.2 is far from a week engine, it is actually very good , but you will notice the difference to your XK , the gearbox is similar , but may well have different electronics .....
as for the ones you have found, the XJR will win hands down in every department even with the higher milage, and to be honest, i wouldnt worry about it, especially if the exterior condition is good or better , and dont forget, the XJR has a different and better Mercedes gearbox......
given the choice, a supercharged XJR would tempt me away from my 4ltr Sovereign
8)
springelec
4L Sport
Postby springelec » Wed Apr 29, 2009 1:37 pm
Hi BB,
I took the XK8 to David Marks yesterday for tensioners etc.
There were no obvious problems, but after reading X308 members' comments about this, I decided to be better be safe than sorry.
David Marks confirmed your comment about the XJR using the stronger Mercedes box and added that younger X308's have an improved engine management mapping, which makes them a bit better compared to earlier models.
He also said there was very little difference in reliability, maintenance and running costs compared to the standard 4L machine, in which case, an XJR seems an obvious choice.
Seems like a 'no brainer' to me, unless you have a particularly heavy right foot ! !. (Which I don't have.)
I'm just waiting now for a nice one to appear, preferably in black with an Ivory or similarly light coloured interior.
The Thoresby Hall event is looking more and more attractive as a window shopping exercise to view in detail what's available and of course to discuss the purchasing decision with X308 owners.
Springelec
Postby Brakebuster » Wed Apr 29, 2009 7:50 pm
cool,
sounds like you know which direction to go now, and youll never regret getting the XJR over a 3.2 Sport
i agree about the light coloured interior, i dont personally like the black, its all a bit too much
happy shoppin
BB :wink:
springelec
XJR Specs
Postby springelec » Thu Apr 30, 2009 1:23 pm
Hi BB,
I agree, so why did Jaguar decide the XJR 100 should be all black ?.
Did they think Sir William was the Prince of Darkness or Batman ?.
I think the XJR 100 would have been better served with a light interior, not black.
Just as well there were only 100 made.
Weight 'n' Stuff:
Where can I find XJR weights, measures & other specs.
Autotrader just repeat the standard weight and dimensions.
For example, a standard XJ is 5024mm long with an ULW of about 1700Kg.
The LWB XJ is about 440mm longer.
Is the XJR based on the standard or LWB frame and what does it weigh ?.
Web sites are all too keen to quote 370BHP etc, etc but that's not much use if the car weighs 15,000 tons ! ! !.
Equally, do power/torque/speed curves exist ?.
These can be calculated, but only if we make assumptions about where peak torque occurs.
For example, if we assume peak torque and power occur at say 4000 rpm, then since P = Tw,
P = 370BHP x 748 = 276760 Watts.
4000RPM = 419Rads/sec and hence:
Engine Torque = 660Nm.
A perfectly valid calculation, but totally meaningless because its based upon the 4000RPM assumption.
Any pointers to a chart or web sites detailing this information would be appreciated
Springelec
Postby ptjs1 » Thu Apr 30, 2009 8:25 pm
Springelec,
You're making the right decision, going for an XJR! If I had the money I would have an XJR instead of my cheap LWB Sovereign!
The max torque is 387 lbs/ft and is produced it at only 3600rpm which makes it even more tractable than the 4 litre n/a which makes peak torque at 4250rpm.
I might be a lone voice but I love the dark colour interior on XJs. I think part of the reason is that I deplore the unfortunate wear that eventually happens on the driver side bolster on all cars - a terrible design. And it always looks worse on light cloured interiors. It never looks so bad on black seats. So if you get a black interior and want to swap for a Catkin one (very rare!) then give me a shout!
Good luck with the search
