Window Glue?
Moderators:robv12, DavidEm
DougX
Window Glue?
Postby DougX » Fri Jul 22, 2022 1:42 pm
I have had the rear window brake light on my X308 keep falling off after using various glue, i.e. various super glues and Araldite. The reason recently has been due to the hot weather experienced. Can anyone recommend something that will do the job PERMANENTLY?
andypryce
Re: Window Glue?
Postby andypryce » Fri Jul 22, 2022 6:02 pm
3M double sided tape, cut to shape around the edge?
XF Sportbrake 2020 / XK8 1998
DougX
Re: Window Glue?
Postby DougX » Fri Jul 22, 2022 6:51 pm
That was what it was on originally, and that peel off!
andypryce
Re: Window Glue?
Postby andypryce » Fri Jul 22, 2022 11:28 pm
Oh! I usually find 3M double sided tape to be pretty good, only other glue I could suggest is gorilla glue, which is generally strong.
xjray
Re: Window Glue?
Postby xjray » Sat Jul 23, 2022 12:37 am
There is a Loctite product that says it works on glass and some plastics;
https://www.loctite-consumer.co.uk/en/p ... glass.html
There is another type on the Loctite website in the US but it doesn’t seem to be available over here;
https://www.loctiteproducts.com/en/prod ... =insideUse
Some years ago I was doing some work at a Formula 1 team HQ where a display company were gluing a deconstructed F1 car to a series of glass panels. It included body and engine/gearbox parts so metal, plastic, carbon fibre, etc, so there must be a suitable product.
Have a look at the Permabond website for UV activated adhesives and perhaps give them a call.
https://www.permabond.com/?s=uv+activated
Ray
1986 Series 3 XJ6 Sovereign
JimMann
Re: Window Glue?
Postby JimMann » Sat Jul 23, 2022 9:53 am
Hi Doug, the people with the correct glue are the auto glass repair companies. Pretty sure if you go along to your local depot, they will be able to sort you out in a few minutes.
Jim
Jim Mann
Banchory
DougX
Re: Window Glue?
Postby DougX » Sat Jul 23, 2022 2:45 pm
Thanks Ray & Jim. Will try both.
