Choice of x308 or x350
Moderators:robv12, DavidEm
taylor6632
Postby taylor6632 » Mon Apr 24, 2017 5:50 pm
After selling my XK8 at a loss due to needing a new engine (was sold it 6 weeks ago as mechanically great, just needing some cosmetic tic) i now find myself with around £2300 left to get another v8, probably a jag as not touching the bmw/audi/merc ones and already got a 4x4 so counts out the land rovers and jeep cherokee.
I'm not sure whether to go for the early x350 3.6v8 or as late x308 3.2 sport i can find locally. Which is the better car and more reliable as the late 90's early 2000's jag v8's seem to be riddled with massively expensive things to sort out whereas the 3.6v8 doesn't seem to have as much negativity online.
Any help would be great.
Re: Choice of x308 or x350
Postby Brakebuster » Mon Apr 24, 2017 6:05 pm
ah , the eternal dilemma
buy the one you like after trying both
two completely different cars in all respects , except for being Jaguars top end car for each of their era's , one steel , the other aluminium ,
Postby J44EAG » Mon Apr 24, 2017 6:17 pm
The X350 is a huge advancement on the 308...great cars that the 308 was.
The 350 is lighter, more economical, does not have the tensioner and other issues of the 308, is made from aluminium which does not rot like a steel car, is bigger inside and out, handles like a sports car, has six gears and surprises almost everyone who drives one. The 350 despite first seeing light of day in 2003, was streets ahead of the competition and even today, those looking at newer cars, find the 350 an almost impossible act to beat.
Your budget is rather on the low side to pick up a 3.5 V8 model. Look hard and you will almost certainly find V6 for that money. Keep an eye out on the carswithnoreserve site who operate from Tilehurst in Reading. They occasionally get a few X350 cheapies.http://myworld.ebay.co.uk/carswithnoreservereading/
Remember that cheap cars usually have issues. You pay for what you get. Buyer beware applies particularly at the banger end of the market.
taylor6632
Postby taylor6632 » Mon Apr 24, 2017 6:25 pm
I had considered the v6 as there are a few more of them about, just always wanted a v8 and its torque. I was told the v6 is ok but its a big car and the v8 pulls it that bit better.
Postby J44EAG » Mon Apr 24, 2017 8:43 pm
The V6 has to run where the V8 just walks. Fuel wise you are probably looking at around a 20% difference.
It is important to realise that either the 308 or 350 require regular high quality maintenance. They cannot just be run into the floor through neglect. Plugs must be changed on time or misfires occur which wreck the coil packs. It is imperative that all engine and transmission oils are changed on time. Avoid any car which does not have documentary proof that gearbox oil has been changed at each and every 60k mileage interval. Any car showing transmission issues will cost at least £2500 to rectify if diagnosis detects severe wear.
Most X350 will require a full suspension bush replacement come 90k miles. The same for the front wheel bearings and brakes.
Please bear in mind that any high performance car is impossible to run for the same costs as a Focus. Parts, fuel, insurance and tax are likely to cost at least double that of a small Ford. Running a 308 or 350 is not a cheap game even if you do the majority of servicing and overhaul work yourself. Hourly garage rates for this type of premium grade car are at matching levels.
RichardSEL
Postby RichardSEL » Tue Apr 25, 2017 8:03 am
There were some XJ8 bargains to be had just before / just after Xmas / New Year. Particularly an '00MY 78k XJ8 3.2L Exec with just three previous keepers that went on eBait for £1,200 -- factor in all the good advice above (timing chain tensioner check £60 or change out to steel if plastic £450, ATF and filter change £180, general service £60, probably ARBs £120, plugs and "stuff", and your adding say another £1,500. You're already over your £2,300 budget.
I've just had that lot done (result on the tensioner though) and with new MOT spent £700 all in, what with the broken drivers' door ratchet strap to re-weld another on
Also try and check when you go to buy that you haven't got a collinder for a rear "A" frame plate. It can be seen easily just back from the rear boxes. Its two visible rear rubbers perish and split. Mine just had surface rust and my rubbers were squashed a bit but not perished
With an "F" in the engine number, said to indicate "Ferrous" meaning steel cylinder liners (late '00MY and up) you're set. Loving mine now, can even get to 26MPG light foot long run. Would've gone for an X350 though had her indoors approved of the extra outlay
Postby ptjs1 » Tue Apr 25, 2017 8:57 am
taylor6632,
The debate between an x308 and an x350 is very topical and constantly being covered by the various jaguar magazines.
As we've seen there will be many different views, so as the previous owner of both models (4.0 Sov x308 and 4.2 SE x350) I'll throw in my 2p-worth.
They are both lovely cars but quite different. If you love the style of the x308, then buy one and buy the best one you can afford. You'll have read all the info on timing chains, cooling tower, water pump, nikasil and gearbox, plus the usual corrosion issues. Unfortunately, you'll need to be very lucky to get a perfect x308 within that budget. You'll definitely buy an x308 at £2k but i suggest that you may need to invest some more money in it.
However, if you just want the best car for handling, performance and equipment, just buy an x350. It's really a better car and apart from a more expensive gearbox service, doesn't have some of the issues of an x308.
You're more likely to get an x350 in your budget that you can just go and do 20,000 miles a year. Jaguar World Monthly have just bought a 4.2 v8 with 113,000 miles for about £2750 and it sounds quite nice. The cars are out there but you have to look hard.
You'll love either car, but don't buy an x308 that needs a lot of work. You could spend quite a bit on it. It's arguable that there is no such thing as a cheap x308 now. You either spend the money up front or you spend it once you've bought it!
Good luck with whatever you decide.
taylor6632
Postby taylor6632 » Tue Apr 25, 2017 5:06 pm
I am now leaning more towards the x350, maybe considering the 3.0 v6 as they are a bit more in my budget with better history, do really want a v8 though.
Also tempted by the cherokee 4.7 HO v8 if i cannot find a decent jag, not quite the refinement of the jag or the ride, but its one hell of an engine and would demote my isuzu 3.1 from the towing duties.
BrizzleJag
Postby BrizzleJag » Wed Apr 26, 2017 10:34 pm
Have a look at Jaguar World interesting article (current edition just out June 2017) which may help you. They have just purchased a X350 for around your budget in good order as one of there magazine feature cars.
RichardSEL
Postby RichardSEL » Sat Sep 02, 2017 11:24 am
Mentioned earlier repair of drivers' door strap
So had it replaced.
This is what to expect if you get that fault.
It's all to do with that daft crystalline metal used for the molding of the stops
emwmarine
Postby emwmarine » Fri Aug 31, 2018 12:13 pm
I would just echo everyone else. An x308, x350 or x300 , for that matter, was never an economy car and to keep them a1 costs the same now as it did when they were worth 30k plus.
They are at that period where their values mean that there are a lot of cars that look good but have been neglected and need a lot spending on them to keep as reliable transport. Certainly all the cheap ones I looked at had stella mileage and had the hallmarks of a money pit.
I suspect that most of the bangers of the x308s are going to fall away very quickly over the next few years and we will be left with a smaller number of cars that have been looked after.
Certainly , if I had 2 to 3 k and didn't have similar in reserve to spend on one I would be looking at a different vehicle.
