Winter off road
Posted: Mon Oct 18, 2021 6:43 pm
by R9KLK
Hello all,
I have a 2007 4.2 coupe, and I’ve decided to lay it up this winter in favour of an old Range Rover. So, my question is, how can I hook up a battery conditioner? I don’t think the battery is particularly accessible.
Thanks!
Re: Winter off road
Posted: Mon Oct 18, 2021 7:53 pm
by andypryce
The best way is to connect terminals to the positive lead on the battery plus to a good earth, and then connect the wires to your trickle charger. Most trickle charges will come with crocodile clips, you can use these but better to add some proper terminals that you can then connect to. The battery is fairly easily accessible, behind the rear seats, just 2 plastic screw fit holders to remove (from within the boot) and pull off the cover. Pretty easy to do. I use a CTEK charger, good and reliable.
Re: Winter off road
Posted: Mon Oct 18, 2021 9:44 pm
by R9KLK
Ah, so there’s no forward connectors in the engine compartment? OK, thanks.
Yes, I’ll use a battery conditioner rather than a simple trickle charger.
Re: Winter off road
Posted: Tue Oct 19, 2021 8:17 am
by andypryce
I am not entirely sure, there may be yes, but if so I suspect they will be for jump starting only.
Re: Winter off road
Posted: Tue Oct 19, 2021 8:36 am
by Thixendale
I understood that it is possible to connect a +ve and -ve lead in the engine bay but only to provide sufficient power to open the boot to access the battery. All jump starts and battery charger connections should be done in the boot.
Tony
Re: Winter off road
Posted: Tue Oct 19, 2021 11:17 am
by andypryce
Definitely true for the X100, is it same for X150?
Re: Winter off road
Posted: Wed Mar 08, 2023 5:27 pm
by Tommyai
As an associated subject, I have just retrieved (2 March) my 2010 XK convertible from a "reputable" classic car storage company. On arrival the battery was flat, as they had failed to connect the CTEK conditioner on delivery in November. Once eventually jump started they assured me the 30 minute drive home would charge the battery. Even after connecting the CTEK overnight, it may be no suprise that the battery was U/S.
I told the storage people of the issue, foolishly expecting a goodwill reimbursement for the cost of the replacement battery, given their failure to connect the conditioner. "Oh no, this happens all the time, these cars unless run daily will eventually kill the battery". I suspect they are fobbing me off. I would appreciate any opinion on this, to confirm or otherwise my current being "fobbed off" position.
Re: Winter off road
Posted: Wed Mar 08, 2023 5:46 pm
by JimMann
Hi, if you are a regular reader of the Modern XK column, or this Forum, you will know that our advice regarding batteries in the Modern XK, especially the X-150, is to replace the battery at 5 years old. Do you know the age of the battery that was in your car?
In one respect your storage guys are correct, leaving an X-150 without a battery conditioner whilst stored will certainly allow the battery to go flat and you should NEVER jump start on a flat battery - all sorts of horrors can result, including a dead battery as you are finding out.
Assume you have now fitted a new battery as per your comments but if you plan to leave the car sitting for more than a week at a time, connect up the battery conditioner, CTEK unit. Also, you may need to visit a garage with the appropriate diagnostic kit to have the battery module in the car updated - telling it there is a new battery installed so as the charging rate gets reset.
Jim Mann
Re: Winter off road
Posted: Thu Mar 09, 2023 7:06 pm
by andypryce
I think if they had connected a trickle charger it should have been fine, as a good one effectively has the same effect as if the car is being used daily. Agree with Jim’s comments regarding battery age.
Re: Winter off road
Posted: Mon Mar 13, 2023 1:12 pm
by Tommyai
Jim many thanks. The storage guys admitted they forgot to connect the charger, and yes they did jump start a very flat battery, which was new in April 22. I have my CTEK conditioner connected now and it appears to be working well. I will have the local garage check the battery module, that is something I wasn't aware of. Tommy
Jim Mann
