X150 Supplementary Service Portfolio
sharpcobsrus779
Postby sharpcobsrus779 » Mon Jan 31, 2022 3:53 pm
Hi, I have recently purchased a 2011 XKR and the service book is full, does anyone know where I can purchase a follow on book . It is part number JJM 10 88 99 111. I have been quoted over £40 plus VAT and "weeks" from my local main dealer. Regards Greg.
Lucky
Re: X150 Supplementary Service Portfolio
Postby Lucky » Mon Jan 31, 2022 4:55 pm
The price seems about what I would expect and I suspect these are printed to order, hence the delay.
I made my own continuation sheets by scanning the existing service book pages and then using MS Paint to clean them up and copy and paste numbers to produce and print all the sheets I will need in the future.
2001 XK8 4.0 Coupe in Quartz
JimMann
Postby JimMann » Mon Jan 31, 2022 5:08 pm
Hi Greg, if you speak nicely to your main Jaguar dealer, they can set up an online service history for your car. This was a service that initially was only applicable to 2013 plate registered cars, but JLR recently changed the system to allow an online service history / record to be created for the older cars. My own XKR is 2010 registered, but it has an online service record.
Jim
Jim Mann
Banchory
Lucky
Postby Lucky » Mon Jan 31, 2022 5:14 pm
Jim,
What sort of garage has access to update that record? Presumably not just the Dealer network.
sharpcobsrus779
Postby sharpcobsrus779 » Mon Jan 31, 2022 7:29 pm
Jim, thanks for that, I will give it a try, what's the worst that can happen !!!!
JimMann
Postby JimMann » Mon Jan 31, 2022 8:50 pm
Hi all, I assume only the dealer network can access an online service history, but perhaps some specialists can be given access as the model age increases.
I got mine sorted a couple of years back and discovered the JLR change by pestering my local JLR dealership. Initially I played the card that I thought the online service history had been taken down for my 2010 Jaguar, even though it was still serviced within the dealer network. Transpires I was doing them a disservice, probably not for the first time, as the online service history I recollected as checking in the past, was for my much newer Range Rover Sport, which does and has always had an online service record.
However, my chase prompted the dealership to speak to JLR and hence discover the change to the system that allowed the older cars to have an online service history. Not sure on who can amend / update the records though.
Jim
Jim Mann
Banchory
