Convertible Roof Lining
Posted: Sun Sep 05, 2010 6:35 pm
by Ian64
Can anyone recommend a way of cleaning the roof lining on my 96 XK8 Convertible. I have tried without much success, leaving what appears to be worse stains than when I started! Can it be removed and if so is it an easy job?
Re: Convertible Roof Lining
Posted: Mon Sep 06, 2010 9:10 am
by mike020150
The procedure for removing the headlining is lengthy (Jaguar trained mechanic's time 2.2 hours, so double it at the least) and quite involved so it's certainly not easy to remove. Like many convertibles, the XK8 often suffers from running with the hood down and no hood cover in position as well as staining from the hood mechanism pivot lubricant. Unless one of our concours experts knows better, care, perseverance and patience seem to be the only secrets to achieving an acceptably clean hood lining. Mike.
Posted: Tue Sep 07, 2010 9:03 pm
by bobwnm
Ian64,
after much deliberation and testing of various cleaning substances on small patches of my convertibles head lining I have had no success, however today whilst valeting my old Suzuki 4x4 I noticed that the back of the front seats was a very similar material to the Jag headlining. My K'Archer valeting M/C loaded with carpet cleaner/ seat cleaner did a superb job removing some old staining!
I have now cleaned the Jag headlining!!! after filling the car with old blankets to soak up the drips I found that I could reach all of the headlining while sitting in the drivers seat with my legs outside & leaning back onto the passenger side. The whole job took less than an hour & I have just been to have a look after leaving the doors open to let it dry for a couple of hours.
The job is definitely a success, I may have missed a couple of bits or not cleaned patches evenly, but that is me being careless. The valeting M/C has done a superb job, I am really pleased because it looks 100% better & if req'd it is no effort to do it again, I hope all this is of some help, if you require more info give me a shout,
Bob
Posted: Tue Sep 07, 2010 9:15 pm
by Nik
That's a great tip there Bob :wink:
What make of liquid cleaner did you use in your machine :?: ,
Regards ,
Nik
Posted: Tue Sep 07, 2010 11:14 pm
by bobwnm
Hi Nik,
sorry I have no idea of what the brand is, I buy it at the local hire shop. When we were using the valeting M/C in anger we bought the cleaner from the makers, but this seems to do the job! I can't even read the bottle cos the guy buys in bulk & rebottles in old lemonade bottles for his own machines!!!!
It is mainly for carpets but I have been using it on car seats , door cards & carpets for years! When you hit the bottom line, it is all textiles
Bob
Posted: Wed Sep 08, 2010 8:55 am
by Ian64
Thanks for your help guys. I hadn't the guts to try the machine cleaner but as Bob is the successful pioneer I will give it a try.
Any of you guys know anything about heated seats? My car doesnt have that option but I read somewhere that Jaguar seats all had the elements; the only thing I would need would be the switch pack and relays.
Its a '96.
Ian
Posted: Wed Sep 08, 2010 9:25 am
by bobwnm
Update on the headlining! after drying & viewing in daylight.
The cleaning is 100% apart from 2 dark lines from side to side across the largest panel, even these are a lot less evident than they were. As predicted I was a bit uneven with the cleaning in places but without a critical inspection the job looks good!
I shall do it again today with more care to get an even result, after all it is an XK.
Bob
