Rear View Mirror
m_hagger
Rear View Mirror
Postby m_hagger » Sat Nov 10, 2007 9:37 pm
Dear All,
My rear view mirror has suddenly developed a line horizontally across its surface. On one side there is a discolouring to a whole area along the top of the glass that looks as though something has gone wrong with the auto-dipping. It looks similar to photo-sensitive sunglasses that have been outside. The glass appears normal elsewhere on the mirror.
Has anyone else experienced this? Does it require a whole new mirror unit, or is it possible to just replace the glass surface?
MarkyM
Postby MarkyM » Sat Nov 10, 2007 10:58 pm
A whole new mirror I'm afraid :(
You've no stated your year of car... from memory they weren't available before 98 and if a newer style mirror has been fitted to an older car the mirror will eventually melt down. Something to do with the 4 pin only switching the electrochromatic on with auto lights...if you car doesn't have auto lights then it stays on permenantly causing the meltdown.
If however your car is a later 4 pin model then no probs except that they do fail...they are normally on Ebay for around £70 but ensure you get the right part no for your car
Mark
Burnham (on Sea)
Somerset
m_hagger
Postby m_hagger » Sun Nov 11, 2007 5:04 pm
Thanks Marky.
I have a '98 model that has auto lights as standard, so I guess this is just a failure based on time, rather than a retro fit of a new mirror to an older car.
Had a quick look on eBay and found one adverstised at £60. The seller also included comprehensive notes on the problems of 8-pin versus 4-pin mirrors and the importance of getting the right one!
Thanks for your help!
GrandTourer
Postby GrandTourer » Mon Nov 19, 2007 10:04 pm
Welcome to the forum, m_hagger :)
I am glad that, thanks to Mark, you have already been helped.
Let us know, how you got on when you have fitted the mirror.
Karl, XK8 MY2000 Pacific Blue
m_hagger
Postby m_hagger » Sat Nov 24, 2007 11:34 pm
Have held off buying a new mirror for the time being. Although it is 'stuck' in dipped mode, the mirror itself is still ok with no real loss of visibility. Might think about replacing it when I'm feeling a little more flush after Xmas! :D
Sharfrs2
Postby Sharfrs2 » Wed Nov 28, 2007 5:08 pm
I've heard that these mirrors are covered by the manufacturer lifetime warranty. If you give them a call they will send you a new one in return for the old mirror. Unfortunately I can't remember the name of the company :(
Remember those that gave their todays for your tomorrows.
MyQuest
Mirror
Postby MyQuest » Thu Nov 29, 2007 8:49 am
Checking the Jag-lovers website (great forum --oops!), I note that USA cars have mirrors made by Donnelly. They have a good name and as stated give a life-time guarantee.
If UK mirrors are the same, check out: http://www.donnelly.com/
Michael
MyQuest
Mirror
Postby MyQuest » Thu Nov 29, 2007 8:50 am
Michael
painter
Postby painter » Mon Feb 02, 2009 3:22 am
I've often wondered what happened to my CD/Radio unit, thought a passenger had spilt nail varnish or similar, but from the description on this topic it seems as though my mirror has 'burst' and leaked. Same symptoms as described, with discolouration within rear view mirror area, and pressing the auto button achieves nothing.
My car is 96, so I guess a retro fit and suppose this means no warranty. Are they worth replacing and can they now be fitted to 96 models?
painter
Postby painter » Thu Mar 12, 2009 1:46 am
what advantage do the 'bursting' mirrors have over a standard rear view mirror. Is it an electronic auto dimming process? and what is the 'corrosive' liquid inside. Further to last post I assume it is still not possible to fit the upgraded mirror, but seems a shame to 'downgrade' :(
MarkyM
Postby MarkyM » Thu Mar 12, 2009 3:37 pm
I think it is possible to retrofit even to cars that didn't have it, but I figure it must be connected to an ambient light sensor or else set up to only come on when your lights are on.
I had one connected to my 96 before it melted down but is still in situ disconnected with only a small off-coloured bubble an indicating that it's frazzled.
Mark
pjnews
'Melting' rear view mirror
Postby pjnews » Sun Nov 08, 2009 10:04 am
Am pleased to report that I was recently able to obtain a replacement rear view mirror for my Nov 96 coupe through the local Jaguar dealer at no cost.
Postby mike020150 » Mon Nov 16, 2009 6:47 pm
Well done! We like good news like that. Mike. :D
