Instrument Cluster Removal X150 2008
DJB72
Postby DJB72 » Sat Aug 31, 2024 12:14 am
Hi. Has anyone any experience of removing the instrument cluster on an X150. I’ve done a little research and it appears to be secured by 4 screws, 2 of them are located behind the trim panel above the steering column? I’ve been advised to invest in a set of trim removal tools. I’m about to send the cluster off for testing as it may well be the cause of a long-standing,intermittent non starting issue.
Any advice would be greatly appreciated.
Re: Instrument Cluster Removal X150 2008
Postby mike020150 » Sat Aug 31, 2024 9:14 am
It's slightly more involved than your description. Namely, begin by carefully removing the instrument panel driver's side reinforcement trim panel (4 clips). Take out the 3 screws holding the instrument cluster surround. Then, remove the two upper screws holding the cluster before raising the steering column finisher for access to remove the lower 2 screws. Disconnect both electrical connectors and the unit should be free. Mike.
DJB72
Postby DJB72 » Sat Aug 31, 2024 5:29 pm
Many thanks Mike. Are the screw heads the hexagonal type?
Postby mike020150 » Mon Sep 02, 2024 10:48 am
Sorry, I can't recall the screw head type and with the minor model year changes during production, they may have changed during the model's run. Mike.
DJB72
Postby DJB72 » Wed Sep 04, 2024 10:54 pm
Thanks Mike.I’ll remove the panel and check.Thanks again for your help
