XK Vibration
RodCotton
XK Vibration
Postby RodCotton » Mon Nov 03, 2014 7:10 pm
My 2006 XK has recently been involved in an accident that required the replacement of the steering rack, nearside suspension, wheel and tyre.
The car came within a whisker of being written off, but it has been repaired and the car looks fantastic again.
However I have a niggle that has only started happening since the accident and has currently got the garage stumped (and is driving me potty)...
When driving below 65 mph the car is perfect, however over 65 there is a pulsing vibration and sound that can be felt throughout the car (i.e. not just through the steering, passengers can hear and feel it so it's not just me). At 65 the pulses are a about a quarter of a second long and come about once a second. If I drive faster the pulses are closer together until at about 95 it is virtually continuous.
If I'm turning to the right (on the M3! I don't do many corners at over 65) the vibrations gets less and can completely disappear if I turn left it gets a bit worse.
The front wheels have been balanced twice, and the car tracks perfectly.
I have spoken to a mechanic I've known for years and he instantly said drive shaft out of balance.
Before I take the car back to the garage again does anyone have any other ideas?
Many Thanks
Rod
Re: XK Vibration
Postby J44EAG » Mon Nov 03, 2014 7:45 pm
I had a drive shaft coupling break up as detailed here on my S-type. Worth a check?
http://www.jec.org.uk/forums/viewtopic.php?f=194&t=7313
I wonder also if you have a damaged engine mount/insulator.
Hope you find the cause.
Re: XK Vibration
Postby mike020150 » Tue Nov 04, 2014 12:54 pm
Obviously a tough one to diagnose, especially remotely. Bearing in mind the accident damage, don't rule out the possibility of an aerodynamic effect. The plastic turning vanes below the front of the car are critical for good air management on X150s but are easily damaged. Air rushing past a poorly attached or damaged panel, eg a wheel arch liner, can set up all sorts of strange noises and even vibrations. The fact that your car only demonstrates the issue at speed and the vibration alters with steering lock could provide a clue that the conditions for just such a problem might be to blame. Mike.
robv12
Re: XK Vibration
Postby robv12 » Tue Nov 04, 2014 4:10 pm
you say a new wheel and tyre, is the existing tyre matched in type and rating to the new one and how much difference is there in the wear??,
whilst I can't comment on XK, I can on X350 , and these cars are critical to good matched tyres and the correct pressure and even wear across front or rear pairs
I have also had wear and damage in a front upper wishbone ball joint that gave a similar condition to the one you describe, and , it was difficult to locate, we only found it by weighting the car in a particular way
You could take the car to XJK in Stoke or David Marks in Nottingham if you are close enough to swing by, both will give and the car an expert going over and diagnosis
hope this helps
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
RodCotton
Re: XK Vibration
Postby RodCotton » Wed Nov 05, 2014 8:35 pm
Thanks for all your thoughts gives me some avenues to investigate and discuss with the garage who did the repairs.
I'll keep you posted.
Rod
