Throttle Pedal?
ng4xjs
Throttle Pedal?
Postby ng4xjs » Sun Dec 24, 2023 7:38 pm
Just a quick question (newish to the X150). Just trying to work out what the travel distance for the throttle pedal should be. I think mine is a little short. And any advice on where to and what is the best technical source please.
Thanks in advance.
Nick
1994 4.0 XJS AJ16 BRG
2009 2.2 X Type Diesel BRG
2007 4.2 X150 Silver
Re: Throttle Pedal?
Postby mike020150 » Tue Dec 26, 2023 6:41 pm
The throttle pedal is just an electronic switch with no adjustment for its travel. The pedal travel isn't linear, i.e. half throttle travel doesn't produce half the effect of full throttle. It produces a greater effect. That way the car can be made to feel livelier at smaller throttle openings. During the XK's production run, Jaguar altered this relationship (reducing the rate at which the pedal signalled initially for power), possibly because the steadily increasing power of the V8 engines was making it more difficult for mere mortals to drive smoothly and avoid wheel spin etc. Full Jaguar or Autologic diagnostics can check if the relationship between the throttle and the rest of the fuelling system is correct so, if you have doubts, a diagnostics session might be the way forward. Mike.
ng4xjs
Re: Throttle Pedal?
Postby ng4xjs » Wed Dec 27, 2023 4:43 pm
Many thanks Mike - I was only just curious around height of peddle as conscious, buried it in the carpet, but all seems to be well and working.
Again, grateful for your input.
Nick
