xk headlights
I have always found the headlights on my 2006 coupe disappointing with poor definition and focus. Polishing the lens made a slight improvement,so I changed the Std. Xenons to Osram Night breaker. These are dearer then Std but with a higher light output which has made an improvement.Checking on the Net for LED conversions I found a few adverse reviews about poor focus although a brighter light so I decided to stay with Xenon. I did find that the lights needed realignment possibly because of removing the headlight units to change the bulbs.
Re: xk headlights
Changing headlamp bulbs or burners for LEDs is not advisable (or legal) unless you use a purpose designed headlamp. The reason is that the geometry of an LED source of light is different from that of a bulb. It's also why there are reports of poorly defined beams when people have tried this so-called upgrade. Mike.
