NO AM SIGNAL
lovejags
NO AM SIGNAL
Postby lovejags » Mon Mar 05, 2018 8:59 pm
I have lost the am signal on my stereo everything else works fine somebody suggested the aerial amplifier could be at fault. Has anyone any ideas also is it situated in the boot or behind the stereo. My car is a 2007 xkr convertible.
Re: NO AM SIGNAL
Postby mike020150 » Tue Mar 06, 2018 11:26 am
If your car has an external aerial, it won't have an antenna amplifier. If it's a 2008 model year car without an antenna, it will have an amplifier and it will have a hardwire connection to the amplifier in the boot. The amplifier is connected to the integrated audio module, via the FM antenna signal splitter, by a coaxial cable. On convertible models, a block connected to the amplifier provides the earth connection through the body. Mike.
lovejags
Re: NO AM SIGNAL
Postby lovejags » Sat Jun 02, 2018 2:30 pm
Hi Mike know it's been a while you say there is no amplifier but I have found one on ebay item no.202075990152. I have looked behind the o/s rear light cluster and the same box is there with 4 connectors .Could you have a look and see if it is.P.S it is an external aerial.
Re: NO AM SIGNAL
Postby mike020150 » Wed Jun 06, 2018 4:55 pm
I suspect you are looking at the AM/FM signal splitter located near the OSR lamp unit. Mike.
lovejags
Re: NO AM SIGNAL
Postby lovejags » Wed Jun 06, 2018 7:30 pm
Thanks for replying Mike does this unit have any bearing on the reception?
Re: NO AM SIGNAL
Postby mike020150 » Thu Jun 07, 2018 8:48 am
With such complicated integrated electronics, I'm tempted to say anything is possible but that's a cop out. The splitter is there to split the FM signal between the radio and the sat nav. I don't know whether, if faulty, it could cut out the AM signal. Have you checked all the simple options, like the tightness of connections between the antenna and the audio unit head?
Rather than risk changing component after component in a lengthy search to find the source of the problem, it would be better to have the audio system diagnosed by the full main dealer diagnostics system or its Autologic equivalent. Good Jaguar specialists as well as main dealers should have one or both systems. For the sake of an hour's diagnostic time, a good technician should be able to pinpoint the fault. Then, for minimal cost, you would know whether or not it would be an expensive repair whilst still giving you the opportunity to decide if it would be worth the cost to correct it. Mike.
andypryce
Re: NO AM SIGNAL
Postby andypryce » Tue Jun 19, 2018 10:14 pm
Interestingly, I have had the exact same problem on mine since purchase, sadly I have no idea why and have not investigated further, as other more pressing things to do! If you do find a solution please post it back, thanks.
XF Sportbrake 2020 / XK8 1998
